Rear axle question
Check to be sure all the copper washers are off. They are a tight fit on the studs and can hold you up from taking the diff out. If the washers are off, then use a screwdriver the pry it away from the housing. I've also had to use a floor jack on the pinion nose. Slowly jack it up until it breaks loose. In either case, be ready with a pan to catch the fluid!
musnicki
Sep 23, 2015 07:11 AM
Sep 3, 2015 07:14 PM
Sep 1, 2015 08:16 PM
