Quick T5 conversion question for those that have done it...
Old Mar 23, 2007 | 05:15 PM
Epic2112's Avatar
Epic2112
Default Quick T5 conversion question for those that have done it...
I'm putting a T5 in my 68, and it looks like it will be a tight fit. Has anyone needed to hammer out the tunnel at all? Has anyone had any scraping or rattling due to the clearances between the transmission and the tunnel?
Old Mar 23, 2007 | 05:28 PM
gothand's Avatar
gothand
Default RE: Quick T5 conversion question for those that have done it...
It should fit in just fine without any hammering on the tunnel. The only place where it can get a bit tight is at the shifter opening, especially with some aftermarket shifters. Worst case scenario is that you have to clearance a bit around the shifter with a cutoff wheel. No biggie, really!
Enjoy the mod. I've done it on two different '65s and don't think I'd own a 4-speed again. The shifter on those was enough to drive me nuts.
Old Mar 23, 2007 | 07:55 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Here are some pics of the clearancing I had to do to get mine in. Other than this little mod it fit perfectly!
[IMG]local://upfiles/27838/426D6112FB2A49C49A36EA83EA7781F0.jpg[/IMG]
[IMG]local://upfiles/27838/15F467DEC78D4E84922C0CD549066332.jpg[/IMG]
Old Mar 23, 2007 | 08:26 PM
mikethebike's Avatar
mikethebike
ORIGINAL: 67t5ponycoupe
Had to cut the same area for mine. Used aluminum sheet to fit opening to shifter.
Where did you get the console mod?
Do you need a bell-housing moded for the t-5?
Old Mar 23, 2007 | 09:03 PM
67t5ponycoupe
That is a stock console with a cougar pad on it. You can go two ways on the bellhousing, Use the old style bell housing and you will need an adaptor plate or use the T5 bell housing and no adaptor plate. You canuse the cable clutch or stock clutch linkage with either bell housing but it will be easier to go with stock linkage on the old style bellhousing and cable clutch on the T5 bell housing.
Old Mar 24, 2007 | 03:51 AM
Epic2112's Avatar
Epic2112
Thanks for the help guys! I was already anticipating cutting the area a bit around the shifter, but I'm glad I don't need to do any hammering.
tmdm
May 2, 2021 02:49 PM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
CarrieS
Sep 1, 2015 01:00 PM
