Vibration
Old Mar 27, 2007 | 02:34 AM
morg68stang's Avatar
morg68stang
Default Vibration
I know that without driving or seeing the car, this is a pretty difficult question for someone to answer, but I've got a vibration and I'm trying to figure out where to start. At about 40 MPH I have a vibration that I can definitely feel in my steering wheel. It makes my tach (mounted to steering wheel) jump up and down pretty rapidly. At faster speeds it tends to decrease in intensity, but becomes faster. It mostly makes my rearview mirror blur out. It seems that at lower speeds (<20) I can feel a little bounce like maybe a tire is out of round or something, but all my tires appear to be wearing evenly. Does this sound like a tire/wheel issue or something else? I know I have a little slack in the rearend and I will be getting a rebuild there in the future, but could this be causing the issue, as well?
Thanks!
Old Mar 27, 2007 | 02:52 AM
Gun Jam's Avatar
Gun Jam
Default RE: Vibration
sounds like tire/wheel to me.
have them check balance.
Old Mar 27, 2007 | 03:06 AM
JMD's Avatar
JMD
ORIGINAL: morg68stang
Thanks!
check your u-joints, you might have one ready to come outa there. Are you sure the slack is in your axle? What you might think is your axle, could be a u-joint,or it could be both.
Based on your description of your problem, I would give odd's on the u-joint being you issue.
I would for sure check the joints, they can be nasty when one drops.
Old Mar 27, 2007 | 03:15 AM
Aussie66Fastback's Avatar
Aussie66Fastback
I'm with Gun...wheel balance.
if it were drive shaft or axle related you would more likely feel it thru the seat rather than the steering wheel
Old Mar 27, 2007 | 03:20 AM
JMD's Avatar
JMD
ORIGINAL: Aussie66Fastback
Vibration can be tricky,, he feels it through the wheel, but the rearview gets blury too.
I could be wrong,,, but I have a hunch.....
You probably are right, but I would still check the u-joints.
Old Mar 27, 2007 | 03:51 AM
Aussie66Fastback
agree...vibes are hard to find and fix.
i wouldnt rule out u joints either but i'd start with the balance
Old Mar 27, 2007 | 10:45 AM
morg68stang
Just had the u-joints replaced a couple of months ago. The last time I was under there, they looked to be in good shape. As with anything like this, though, I'm having a hard time remembering what the car was like before the u-joint replacement. I didn't drive it much then. I think I'm going to take it in and have the balance checked on all the tires. That's an easy check and can rule out a possibility pretty quickly.
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
mdj89
Sep 23, 2015 08:49 AM
ccdguy
Sep 19, 2015 05:20 PM
