Help me get started
Old Mar 29, 2007 | 11:15 AM
PReal's Avatar
PReal
Default RE: Help me get started
ORIGINAL: Soaring
Just for grins, check the wire from the distributor to the points to make sure there is a solid connection there.
It is the orignial dizzy and wires, so this might be my problem source.
I will be checking this and spark tonight.
Old Mar 29, 2007 | 11:43 AM
kalli's Avatar
kalli
if you don't have any spark then check for dwell as well. when the points don't open or don't close you won't have any spark.
Let us know if you need to know on how to check for that.
Checking for spark:
best thing to do is to get a good known spark plug (any you'd have lying around) and hook it up to one of the wires.
Hold the spark plugs thread to ground (battery minus or engine block) and see if that gives you a spark when you try and start the engine
Kalli
Old Mar 30, 2007 | 12:54 AM
PReal's Avatar
PReal
Well, I jstu got out of the garage and I have spark.
What would I need to do to make sure I'm not flooded.
Also, the exhaust is in really bad shape, is there a possiblity too much back pressure couldprevent the engine from starting.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
