Master Cylinder
Old Mar 29, 2007 | 02:41 PM
cole18cars's Avatar
cole18cars
Default Master Cylinder
I'm changing out a single bowl m.c. on a 66. I'm replacing it with a 74 Maverick dual bowl. [disc up front, drums in back] My question is I can't get the push rod out of the old m.c. Is there a clip or ? on the end of the push rod? Also I was told to use the old push rod since the 74 is too long? Thanks
Old Mar 29, 2007 | 03:06 PM
19stang66's Avatar
19stang66
Default RE: Master Cylinder
IIRC there is a clip on the very end of the rod. I think I had to use a hacksaw and cut through something to get my old rod out. That was a few years ago so my memory is a lil foggy.
Old Mar 29, 2007 | 05:49 PM
gothand's Avatar
gothand
Some have clips and some don't (or are missing). If you haven't already done so, remove the rubber boot so you can get a good look at the clip. I "think" you can put the rod in a vice and give the base of the old MC a smack to knock it out.
BTW, you are correct to reuse the stock rod.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
