Dim Headlights?
Old Mar 31, 2007 | 05:22 AM
hardroxs19's Avatar
hardroxs19
Default RE: Dim Headlights?
Yeah I have a 100amp alt. and the sylvania cool blue headlights, but the its mainly the passenger side headlight thats dimmer.
Old Mar 31, 2007 | 06:21 AM
longlive289s's Avatar
longlive289s
wish i had my stang on me. i know stock amps is bout 90amp.....think my new one was bout 130-140ish. got it after....mmmmm....small "accident" on my car. caused me to redo all the wiring, alt, etc.
Old Mar 31, 2007 | 09:14 PM
JamesW's Avatar
JamesW
A little hard to see in this photo..but I've recently gone over the Tri-Bars like you see in the street rods with the replacable Xenon bulb. They work pretty sweet.
Old Mar 31, 2007 | 09:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: JamesW
I imagine with the addition of the relay mod and those bulbs you are pretty bright. I have to try and find those relays. I will check at the local parts house on Monday.
Old Apr 1, 2007 | 12:52 AM
6mustang6's Avatar
6mustang6
I have the aftermarket Headlamps that allow the use of 9003 bulbs. I put H3 bulbs in them because it said those are the ones. Those are motorcycle lamps however. So i bought Silverstar H3's and also did the relay upgrade. They're brighter, but still nothing on a new car. Maybe it's the motorcycle bulbs, instead of the right 9003 bulbs. You can tell a difference is brightness when you install the relay system. I cut the wire and i had the lights on the regular way and when i touched the wire with the wire from the battery they got brighter.
Old Apr 1, 2007 | 01:07 AM
mySAVIOReigns's Avatar
mySAVIOReigns
I got mine in the mail today Thanks James. I ended up accidentally getting an extra pair of sockets, so if anyone wants them ...
Old Apr 1, 2007 | 01:13 AM
6mustang6's Avatar
6mustang6
Buying those expensive relays and sockets are a waste. I bought a $4 relay from my work that was actually made for running lights. Then some wire, and a few connectors. Cost me $12. Lights, WA LA!
Old Apr 1, 2007 | 08:58 AM
kalli's Avatar
kalli
i'd say if you have a scrapyard round the corner, just pull them from some more modern car.
Old Apr 1, 2007 | 10:48 AM
JamesW's Avatar
JamesW
They are cheap new. The shipping cost more than the parts. Most Auto Parts Stores sell the relays. If you don't want to buy the sockets, you can use spade connectors to plug in. Just make sure you put shrink wrap around the spades as protection, and zip tie the wires very securely.
Old Apr 2, 2007 | 01:07 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
ya you can get some good lights but i recomend that if you are gunna add those relays that you replace all the woring to the bulbs from the relay and silverstars are great but they have a longevity problem they don't last very long if you want bright get the conversion as shown above and then get the little bit brighter bulbs i think the 85/95 W bulbs to go in
StalkerGT
Nov 28, 2015 03:09 PM
Seanam
Oct 4, 2015 10:15 AM
Drastang
Sep 29, 2015 03:31 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
