Top loader & Bell housing
Old Mar 31, 2007 | 03:32 PM
scuf23's Avatar
scuf23
Default Top loader & Bell housing
As I am going through my car to figure out the issues, I cam up with the following questions
- Is there only one type of bell housing for a given engine? my engine is a 289 and my bell housing ID is C5DA-6394-A which is consistent
- Is it possible to install a top loader that was on a bigger engine on a 289? my toploader is a RUG AV1 which means it is coming out of either a 302 or a 351 ... my first answer would be yet since it is the set-up on my car but I am wondering if this could be the source of some issues I have had (issues listed on a previous post - Thanks!
Old Mar 31, 2007 | 05:08 PM
easttennmotors's Avatar
easttennmotors
Default RE: Top loader & Bell housing
it should go with no problems
Old Apr 1, 2007 | 01:27 PM
67t5ponycoupe's Avatar
67t5ponycoupe
The big block transmission input shafts are shorter. That is the only difference I know of. That should not apply in your case.
Old Apr 1, 2007 | 03:49 PM
scuf23's Avatar
scuf23
Interesting - would someone know the lenght difference? - would this difference impact the fork clutch adjustment? as I mentionned before, one of my issues is very short clutching, with my fork adjustment being maxed out ...
Old Apr 1, 2007 | 04:06 PM
mikethebike's Avatar
mikethebike
ORIGINAL: 67t5ponycoupe
Too my knowledge the input shaft are all the same length, but the big motors had a 1 3/8" vs 1 1/8" for the small motors and the big-input shaft were a 2.32/1 and the small motors was a 2.78/1 ratio. The bolt paterns were the same. The output shafts were different based on the wheel base of the car they were going in. ANY 3 or 4 speed top-loader should fit the bellhousing of any other top-loader.
Old Apr 1, 2007 | 05:37 PM
67t5ponycoupe
I'm sure there are pleanty of folks that know more about this than I do. I'm just going off my only experience with this. 100 years ago I tryed to put a big block topleader behind a small block and assumed the shafts were the same. The new trans went in great! Easiest one I ever put it! Problem was it went in so easy because the shaft was not in the pilot bearing. It worked and moved the car but there was a vibration and the trans front bearing was making noise. Pulled the trans to compare and found the short shaft. Traded that input shaft with a shaft I had from an early model small block toploader, the one with the narrow bolt pattern on the front of the trans, and everything was golden.
Old Apr 1, 2007 | 05:39 PM
67t5ponycoupe
I think Mikethebike is talking about one of those superwhumpadyne NASCAR toploaders. Those things have bigger everything.
Old Apr 1, 2007 | 07:12 PM
ih8chevy's Avatar
ih8chevy
well from seeing that the windsor is a consistent family meaning that most parts from one motor will fit another. and that the t5 in my fox on my 302 will fit a 351 and 289, the 4 speed should fit. dont kno for sure though.
Old Apr 1, 2007 | 07:49 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Top loaders for big blocks were different, but an input shaft for a small block will fitjust fine. That's how mine is set up right now.
Old Apr 2, 2007 | 09:14 AM
mikethebike
No. Stock top-loaders in 427/428/429 cars and most 390 cars were 1 3/8" input shafts. Call Dan Williams in NC and he'll tell you all about them AND how expensive it is to repair them, that's why I went with a T-5.
lincolnshibuya
Jul 5, 2020 03:05 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
