No Spark
Old Apr 4, 2007 | 12:28 AM
stang30's Avatar
stang30
Default No Spark
I am having a problem and I have tried almost everything to correct it. I do not get a spark when I try to start my 1966 I6. I have a new battery, new distributer, new dist. cap, new plugs and wire. I have tested the wires. It appears that I am not getting any fire from the hot wire that is connected to the coil. I have a new coil. Has anyone had this problem and can you tell me what you did to fix it. I am open to suggestions.
Old Apr 4, 2007 | 12:33 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: No Spark
OK, are you absolutely sure you have the (BAT.) battery or (+) plus on the coil hooked up to the battery? The negative (-) or ALT side of the coil goes to the distributor for the points. Get back afteryou double check this.
Old Apr 4, 2007 | 02:18 AM
66GTKFB's Avatar
66GTKFB
As a trouble shooting technique, put a jumper wire from the battery to the coil and try to start the car. DO NOT KEEP THIS JUMPER IN PLACE FOR ANY LENGTH OF TIME WHILE RUNNING. Your coil uses 6-8 V to operate via a resistance wire from the ignition switch to the coil. When in the start mode, 12 V is applied by the solenoid directly to the coil only while the starter is engaged. If it starts, it's the 12 V wiring, if it don't, it's the coil or distributor. And check to see if number one cylinder is at top dead center, not 180 deg out.
Jim
Old Apr 4, 2007 | 04:16 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: 66GTKFB
Jim
Actually, the coil should register over 9 volts at the + side of the coil. If it doesn't, then the battery is not producing enough voltage.
Old Apr 4, 2007 | 09:52 AM
stang30's Avatar
stang30
I am out of town until Friday but I will try to jumping it. I will get back to you this weekend with the results.
Thanks
Old Apr 4, 2007 | 10:01 AM
66builder's Avatar
66builder
You didn't say if you had the engine out recently, but check the ground strap from the engine to the firewall. No ground=no spark, no matter how good everything else is.
Old Apr 4, 2007 | 01:25 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
+1 on checking for a good ground.
Dathan
Oct 5, 2015 05:52 AM
dalehunter
Sep 25, 2015 10:51 AM
lmurf60
Sep 24, 2015 10:07 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Emblazoned
Sep 3, 2015 10:45 PM
