engine problems
Old Apr 8, 2007 | 09:38 PM
6mustang6's Avatar
6mustang6
Default engine problems
Ok, Lets make the story short and say that i drove my car with the timing advanced ALOT..... The car stalled out up the road, and i readjusted the timing back to its normal position. It still wouldnt start. it started after 5 minutes turning over. I drove it home, it ran fine, idled, reved up fine, etc. I went to start it this morning and it wouldn't start for nothing. I put a new distributer in it today, and it started after awhile. I took it for a spin, and when i punched it at like 5-10 miles a hour, the car bogs quickly and cuts off. Then it takes another 5 minutes to start it again, usually whgen i advance the timing, it'll start again. Once it runs, it runs great. This is really bogging my mind.
Old Apr 8, 2007 | 11:19 PM
mustanglover66's Avatar
mustanglover66
Default RE: engine problems
sounds like some of the problems my77stang was working on watch out
Old Apr 8, 2007 | 11:41 PM
toolwench's Avatar
toolwench
It almost sounds like it could also be a fuel delivery problem...as in too much fuel and it's flooding.
Old Apr 9, 2007 | 12:59 AM
6mustang6's Avatar
6mustang6
Well, Im suspecting the carburator, but what is causing it to start once i advance the timing?
Old Apr 9, 2007 | 01:27 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
sounds like you shoulda not touched your timing
Old Apr 9, 2007 | 06:08 AM
JMD's Avatar
JMD
ORIGINAL: toolwench
+1, My first thought also.
Old Apr 9, 2007 | 06:10 AM
JMD's Avatar
JMD
ORIGINAL: 6mustang6
yea thats the part I don't get either,,,, could your coil be bad??? coil could be intermitant.
(might start with the timing change due to luck/coincidence?)
Old Apr 9, 2007 | 07:16 AM
kalli's Avatar
kalli
check if you get spark when it doesn't start
Old Apr 9, 2007 | 10:37 AM
6mustang6's Avatar
6mustang6
Haha, i know i shouldn't have messed with timing, thats a good idea, ill check for spark next time. It cant be the carburetor? Thanks guys, im really mad about all this. [:@]
Old Apr 10, 2007 | 12:57 AM
6mustang6's Avatar
6mustang6
Well guys, here's the dealo. I pulled out all the plugs, and they were dirty, but i checked each one for spark and cleaned them. The timing is right, they plugs are sparking, etc. The only thing I noticed was the spark wasn't consistent when i was turning over the engine, I wonder if this is the coil or pertronix, even though both are around a year old. Also, the plugs are wet like the carb is flooding, idk.I NEED MY CAR FIXED, What can this possibly be.
