clutch pivot
Old Nov 25, 2004 | 09:23 AM
skidado's Avatar
skidado
Default clutch pivot
I am putting a late model 5.0l block into a '67 and want to use the '67 bellhousing, clutch equalizer bar etc.
There was a tapped hole in the '67 block for the clutch equalizer bar pivot, but this doesn't exist on the 5.0l block. I understand there is a bracket that replaces this hole for use with the 5.0l block.
Does anyone have sketches/drawings/dimensions/pictures of this bracket so that I can fabricate one? I am in the UK (England) and I am having trouble finding the bracket over here.
Many thanks
Skid.
Old Nov 25, 2004 | 11:55 PM
roundman's Avatar
roundman
Default RE: clutch pivot
can't help you with the bracket but you might want to rethink the idea of re-using the '67 bellhousing as I don't think they are compatible with the 5.0 blocks, but I'm no expert so get a second opinion from someone. you might try calling the Ford tech hot line listed at the top of the 5.0 tech section and ask the experts there.
Old Nov 28, 2004 | 04:33 PM
bob emmerich's Avatar
bob emmerich
I cannot help you with dimensions, but Mustangs Unlimited sells them. They cost around $60(U.S.). Did you try ebay?
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
MasterLanMan
Sep 13, 2015 08:21 PM
