points conversion
Old Nov 26, 2004 | 10:20 PM
fireball1969's Avatar
fireball1969
Default points conversion
hi every one got a question i have a stock 1969 mach 1 i was interested in converting the org igntion form points to electronic,but i dont want to loose the org look i have seen these kits that just replace the stock points,are they worth it or not if any one knows about these systems thank you verry much.
Old Nov 27, 2004 | 02:54 PM
ClaptonFan's Avatar
ClaptonFan
Default RE: points conversion
I've heard alot of good things about the Pertronix Ignitor system. I plan on making the switch myself in the next couple of weeks. If you do decide to make the change, go with the Ignitor instead of the Ignitor 2. the Ignitor 2 is supposed to have issues with stalling at idle.
Old Nov 28, 2004 | 04:22 PM
bob emmerich's Avatar
bob emmerich
The Ignitor is worth it. If the wire is wrapped well, you can hardly distinguish it from stock.
Old Nov 28, 2004 | 05:01 PM
Soaring's Avatar
Soaring
I ♥ Acer
And while you are at it, get the flamethrower coil as well. Then gap your plugs to about .038 or so. Much more efficiency with this set-up.
jwog666
Dec 27, 2021 08:09 PM
flash_xx
Oct 16, 2015 07:23 AM
marc954
Sep 29, 2015 03:05 PM
Sep 25, 2015 09:06 AM
