1966 Mustang gages dont work??help
Old Apr 14, 2007 | 10:16 PM
rizzy's Avatar
rizzy
Default 1966 Mustang gages dont work??help
I put in a new instument cluster voltage regulator and still nothing???Did I install the regulator correctly?
Old Apr 14, 2007 | 10:19 PM
colostang's Avatar
colostang
Default RE: 1966 Mustang gages dont work??help
I don't know. But that is a sweet interrior. I like that shifter.
Old Apr 14, 2007 | 10:22 PM
350kmileFord's Avatar
350kmileFord
Don't wanna sound like a jerk, but is there any chance the fuse is blown?
Old Apr 15, 2007 | 12:06 PM
JamesW's Avatar
JamesW
First, did you make sure you hooked up the ground wire from the instrument panel to the back brace? Did you go back and recheck all your connections to see they are correct?
Did you check to see you are getting 12V to the IVR Lead with the switch on?
You can test the IVR to see if it's putting out the 5V required by using a volt meter. Here's how they work:
ChampInSD
Oct 2, 2015 04:55 AM
jesse1125
Aug 25, 2015 05:52 AM
Barcafut13
Aug 13, 2015 08:05 AM
daytooday
Aug 11, 2015 09:22 AM
Barcafut13
Aug 10, 2015 07:44 PM
