Steering
Old Nov 30, 2004 | 02:13 PM
JPaikos's Avatar
JPaikos
Default Steering
I am going vintage racing and my 66 mustang need to have manual steering. What is the difference between a power steering rack and a manual steering rack? Can I take off the power steering bits (ram, hoses, etc...) and have a stock manual rack, or are the racks different?
Old Nov 30, 2004 | 03:44 PM
69mach1377's Avatar
69mach1377
Default RE: Steering
Manual costs less to begin with and offers more road feel, a good thing for vintage racing. Not sure if removing power supply is acceptable form of manual R&P...ask the manufacturer for their advice.
Old Nov 30, 2004 | 04:27 PM
69FECoupe's Avatar
69FECoupe
There is more to it than just removing the power assist parts. The center link, idler arm and pitman arm are different. The manual and power boxes are different ratios also. Considering you are racing, you would be safer converting the entire steering system to the proper manual parts.
Old Nov 30, 2004 | 04:43 PM
69mach1377's Avatar
69mach1377
True Coupe, but no such parts in a rack and pinion setup...I thought that was what he was asking about. Your advise about the power assist parts probably applies to R&P also though.
Old Nov 30, 2004 | 05:17 PM
69FECoupe's Avatar
69FECoupe
Yea, at first I thought he was talking about a power rack too. But then he mentioned the "ram" which only exists on a slave/valve set up.
Old Dec 1, 2004 | 04:33 AM
JPaikos's Avatar
JPaikos
Nope, no rack and pinion allowed. The car has to set up as it raced in the 60's. That means rear drum brakes, stock A Arms and lower control arms, 15" wheels, 289ci, etc..., and yes, manual steering. Guess that means a trip up north to NPD this saturday. OH DARN!!
Old Dec 1, 2004 | 12:53 PM
69mach1377's Avatar
69mach1377
In that case, you need all manual parts. I would recommend a new flaming river gear box (2 ratios available), but used solid parts are good enough for the balance. You probably want a new 'rag joint' also.
lincolnshibuya
Dec 8, 2020 01:49 PM
CS2007
Jun 25, 2019 09:45 PM
allenmaty
Sep 24, 2015 09:17 AM
stark777
Sep 21, 2015 12:46 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
