brake trouble
Old Apr 16, 2007 | 12:15 AM
dougscj70's Avatar
dougscj70
Default brake trouble
I just restored a 70 fastback I did not drive before i restored it. I can,t get the brakes to work rights. When it was restored I replaced the following with new parts. Booster ,master clyinder (twice), lines,combination valve,rotors,drums , wheel cylinders, calipers,pads and shoes. The brake will not lock up it feels like somthing iis stuck under the pedal . works fine when you bleed the brakes . The pedal feels good and I can feel the booster working when I start the car. I am running a cam but have run larger with no problem. Let me know if you have any ideas.
Thanks
Old Apr 16, 2007 | 01:02 AM
JamesW's Avatar
JamesW
Default RE: brake trouble
Did you bench bleed the master cylinder before hooking it up?
Old Apr 16, 2007 | 01:26 AM
DenDen's Avatar
DenDen
I just did a major brake job on my car and had to bench bleed it 3 times before it worked right.the problem is the proportioning valve had lots of air in it,the air kept migrating into the master cylinder.the master is tilted up slightly and air cant escape.it has to be tilted down at front to let air escape.Its always a good idea to soak the proportioning valve body in brake fluid overnight before installing it.
CS2007
Jun 25, 2019 09:45 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
