Aluminum Vs. Copper
Old Apr 21, 2007 | 04:30 AM
remicks's Avatar
remicks
Default RE: Aluminum Vs. Copper
Hey James could you give me the specs on your radiator, possibly a part number or where you got it, thanks.
Old Apr 21, 2007 | 04:48 AM
longlive289s's Avatar
longlive289s
ORIGINAL: Soaring
Yeah, technically the copper/brass, but the aluminum can be hammered out to a lot thinner metal and still have the tensil strength, so therefore the ability to dissipate heat well. There is no doubt that an aluminum radiator is the best choice, but if moolah comes into play then the 3 or 4 core copper/brass will work well, My old 65 never gets above 1/3 of the way on the heat gauge and I have a 4 row copper/brass. Other things come into play too, The number of blades on the fan makes a difference in how much air is pulled through the rad, and a shoroud concentrates the air to the center of the rad and an overflow tank helps to keep the rad full at all times.
+20
i switched to a 5 bladed fan and have the same set up with a 4 row. works like a charm but switched out the thermo for a 180 i believe. had a 190 in their before. car has never even come close to overheating
probably could use just water during the summer[8D] jk
baddog671
Jul 26, 2016 01:20 PM
Vrooom
Feb 21, 2016 05:25 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
JT76
Sep 20, 2015 11:32 AM
TfcCDR
Sep 12, 2015 04:13 PM
