2 tubes
Old Apr 17, 2007 | 10:16 AM
dr1965's Avatar
dr1965
Default 2 tubes
After hooking up the headers, i noticed there was a tube going on to the old exhaust manifolds, it comes from the air/fuel rich,lean dial. Now what do i do with this pipe/tube? Also found the o-ring around the trans dip stick tube leaking, How the hell so you get to the o-ring? Looks like a real tough spot to get to.
Old Apr 17, 2007 | 12:14 PM
NorCalTroy's Avatar
NorCalTroy
Default RE: 2 tubes
I think the tube on the old manifold that you are referring to is for the choke stove. Do a forum search and you will find a bunch of information. Basically it allows hot air to activate the bi-metal spring in the choke housing.
They have adapter kits for after market headers ( http://performanceparts.com/part.php?partID=1354 ) or you could convert your choke to an electric one.
Good luck!
Old Apr 17, 2007 | 01:15 PM
dr1965's Avatar
dr1965
Default RE: 2 tubes
Is it more for cold weather? I don't drive mine in the cold.
Old Apr 17, 2007 | 01:27 PM
dr1965's Avatar
dr1965
Default RE: 2 tubes
anyone have any pictures of thechoke stove header kit?
Old Apr 17, 2007 | 01:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 2 tubes
Troy just gave it to you.
Old Apr 17, 2007 | 01:59 PM
NorCalTroy's Avatar
NorCalTroy
Default RE: 2 tubes
The choke is used when the engine is cold. It causes more fuel to enter into the engine so it warms up better/faster. People do run their cars without them, but it's relatively cheap to get the adapter or an electric choke. If you follow the link in the above post, there is a picture of what comes with the adapter kit.
Old Apr 17, 2007 | 02:01 PM
dr1965's Avatar
dr1965
Default RE: 2 tubes
sorry, i am retarded today, my mind is crashing. i ment a picture of it installed on aheader.
Old Apr 17, 2007 | 03:19 PM
highhilleer's Avatar
highhilleer
Default RE: 2 tubes
Since you are modifying the car with headers I think the electric choke option is much better, cleaner, easy to install, modern technology, more reliable.... probably cheaper.
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
Sep 17, 2015 07:57 PM
BrantleyS550
Sep 14, 2015 04:18 PM
