Hard starting when warm
Old Apr 25, 2007 | 03:08 AM
  #41
xBenzinx's Avatar
xBenzinx
Default RE: Hard starting when warm
ORIGINAL: Soaring
ORIGINAL: mat11089
What a bad coil?Ive come across same symptoms and that was the case.
The car starts fine when cold. If it was the coil it would be the same symptom when it was cold. But, just to make sure, use that same multi-meter and check the DC voltage at the coil when it is hot. It should be just under 10 volts DC.
So, there you are. It is most likely one of these guys.
1. Timing too advanced
2. Vapor Lock
3. Hot starter
4. Bad coil.
Let us know which one it is.
/agreed
My coil went bad on me and boom - nothing. Hot or cold she wasn't starting.
Old Apr 25, 2007 | 05:41 AM
  #42
andrewmp6's Avatar
andrewmp6
its lack of a carb spacer get one its the cheapest fix listed and if it dont fix it doesnt hurt to run one cheapest way to fix a hot starter is this http://store.summitracing.com/partde...p;autoview=sku
Old Apr 26, 2007 | 05:12 PM
  #43
BigIron22's Avatar
BigIron22
any update on your hard starting when hot
Old Apr 26, 2007 | 05:16 PM
  #44
sxs191's Avatar
sxs191
http://auto.howstuffworks.com/framed...ewtrouble.html
Don't know if this will help but page down till you get to the Warm Starting Problemsection.... Good luck.
Old Apr 26, 2007 | 06:53 PM
  #45
burnettt's Avatar
burnettt
+1, when i had this prolem this was the cure
ORIGINAL: toolwench
Do you have headers? Your starter might be getting heat-soaked.
Old Apr 26, 2007 | 09:12 PM
  #46
dr1965's Avatar
dr1965
i may have this issue as well, after car is hot, it is hard to start, headers are on. Does that heat rap work well on the starter, or is it just a bandade till i can get money for a good starter.
Old Apr 26, 2007 | 09:14 PM
  #47
ponyx2's Avatar
ponyx2
Like I said, it is eaither the starter is drawing too many amps (heat soaked= no good) or the cables/ground is shot.
Old Apr 26, 2007 | 09:15 PM
  #48
ponyx2's Avatar
ponyx2
either works too, LOL
Old Apr 26, 2007 | 11:01 PM
  #49
andykbob's Avatar
andykbob
Sorry Guys no updates today, Had a couple of busy days. I will get on it on the weekend
Old Apr 26, 2007 | 11:44 PM
  #50
dr1965's Avatar
dr1965
do you have to remove starter to install the heat shield?
