New promblem
Old Apr 25, 2007 | 04:48 PM
  #21
NorCalTroy's Avatar
NorCalTroy
Default RE: New promblem
ORIGINAL: eholzer07
Try to get your afterfire fixed first. If your timing is off it doesnt matter how much you mess with the fuel/ air mixeture, you car will still not run right. Let the car cool down then loosen the distributor bolt just enough so that you can start it. Start the car and turn the distributor slightly one way. If it runs worse try turing the other way. If this fixes your backfire problem then move on to fixing the air fuel mixture. I think you timing is off and your pumping WAY to much fuel into the cylendars to make up for the bad timing. That would explain the flooding and the wet spark plugs.
I agree that if the timing is off it could cause the adjustments made to the air/fuel not to be accurate. Timing should be set before carb adjustments are made. However, I would guess that since there is no mention of any hard starting conditions, or actual backfires while starting, the timing is not off enough to cause any other issues.
A more accurate way to adjust timing is to actually use a timing light. Anywhere between 6 and 10 degrees BTDC should be OK. If you are just moving the distributor without any reference to what the actual timing is, you may be compensating for an incorrect setting somewhere else (air/fuel) and when you actually correct that setting, the timing will be off again. You will be chasing your tail continuously.
Timing with a timing light, then air/fuel mixture with a vacuum gauge.
Old Apr 25, 2007 | 05:02 PM
  #22
dr1965's Avatar
dr1965
I do have a guy i work with, that is all carbs. He did offer to give me a hand, and get it right. What is upsetting is it ran fine, now i have a mess on my hands. Nice weather is here, should of had a car cruise this weekend, just very frustrating. I know we have all had issues with our cars, hell they are anywhere from 10 to 42 years old, its going to happen.
Old Apr 25, 2007 | 05:26 PM
  #23
eholzer07's Avatar
eholzer07
I find when I get frustrated to stop completely for the day getting on here helps alot. Then new things come up and new ideas and working on the car becomes very enjoyable again.
Old Apr 25, 2007 | 05:33 PM
  #24
dr1965's Avatar
dr1965
i agree, time to put it aside for a day, and pick it back up at a later day, when i am clear headed.
Old Apr 25, 2007 | 11:00 PM
  #25
dr1965's Avatar
dr1965
pulled the plugs tonight, found number 4 not fireing. All other plugs slight blackness to them, but not real bad, number 4, look like it just went in out of the box. I have a new coil, so i am thinking points? or cap and rotor?
Old Apr 25, 2007 | 11:35 PM
  #26
JamesW's Avatar
JamesW
and you're positive you've traced every spark plug wire from distributor to plug and they are all in the correct order? backfiring on one side usually means you've got two plug wires crossed.
Old Apr 25, 2007 | 11:39 PM
  #27
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: JamesW
I agree with Jimmy, double check the firing order. It's easy to fug up.
Old Apr 26, 2007 | 12:16 AM
  #28
dr1965's Avatar
dr1965
dudes, i must be f'n retarded. 2 and 3 wires-WRONG. I checked that sucker 3 times, i have no clue how i messed up. See what happens when you walk away and clear your head. A stupid mistake, that drove me nuts for 2 days. Proves when you get frustrated, walk away. Thanks again, and i am not a dumb person, honest.
Old Apr 26, 2007 | 01:27 AM
  #29
JamesW's Avatar
JamesW
Been there..done that...
When I put in my engine ..it was backfiring horribly...
I had 3&4 backward....
Old Apr 26, 2007 | 06:07 PM
  #30
dr1965's Avatar
dr1965
now she runs real good and sounds GREAT. I think i need to replace the choke pot though. Throttle stuck on me when car was warmed up. I hate that dam choke pot, anyway around it?
