289 ID Help Needed
Old Apr 25, 2007 | 08:08 PM
mustangny's Avatar
mustangny
Default 289 ID Help Needed
Trying to see if any of this photo of casting numbers can help identify what 1965 289 we have. Any/all help and insight would be greatly appreciated. It reads as follows: C5AE-9425 D / and above the 289 4 it looks like the stamping of a T or Y???
Thanks in advance for any assistance you can provide.
[IMG]local://upfiles/67615/C57CB74257CF4B80A2730D642BF84694.jpg[/IMG]
[IMG]local://upfiles/67615/B45433A0B7EB478081BB0BB69266D9B8.jpg[/IMG]
Old Apr 25, 2007 | 08:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: 289 ID Help Needed
See if this helps.
http://www.classicmustang.com/decoding_part_numbers.htm
Old Apr 25, 2007 | 08:47 PM
66GTKFB's Avatar
66GTKFB
That's the intake manifold and by looking at the carburetor, you can tell if it's a 2 or 4 barrel manifold. As to the engine, the casting number is located above the starter (you got to remove the starter) with a date code possibily telling you just a little bit more (rev maybe). If it still exist, there may be an aluminum tag attached to the intake manifold that gives even more info.
Jim
Old Apr 25, 2007 | 09:01 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, you can use that information I gave you to break down any part on the engine to include the block. Take your starter out and copy down that number that is on the block. Either give that number to us, or use the information I gave you to decifer which 289 you have. The problem with identifying parts, is that those parts may have been changed out over the years, so your best bet is to decifer the block casting number.
ChampInSD
Oct 2, 2015 04:55 AM
MusicCity615
Sep 27, 2015 12:53 AM
kdryan
Aug 21, 2015 04:01 PM
ding56
Aug 14, 2015 02:40 AM
defarmer
Aug 13, 2015 06:40 AM
