Speedometer not reading correct
Old Apr 30, 2007 | 03:08 PM
groho's Avatar
groho
Default RE: Speedometer not reading correct
go to http://www.tciauto.com/Products/Tech...eedo_gears.asp, about half way down the page, just plug and play. The only problem, you don't know if your C4 drive gear is 7 or 8 tooth. An option is to take your existing speedo gear count, probably 16. Don't know what tire you're running, but you either need a 21-22, or a 24-25tooth speedo gear depending on the tranny drive gear. There is no determining your drive gear unless pull the tale section of the tranny. You might be able to count with a good mirror, agood eye-ball, and a flash light.
Old May 5, 2007 | 09:49 PM
RayM's Avatar
RayM
I took the gear out and it isa Type A, Green, so I see that is a 17 tooth gear, my options from NPD are below, I could not see the gear inside tranny to see if 7 or 8 teeth. I guess it is trial and error at this point.
Should I order a 19 and a 21, or should I stay close. 18 and 20?
Type 3 Blue, 16 tooth, RH rotation........17271-2 7.11
Type 3 Clear or green, 17 tooth, RH......17271-4 7.60
Type 3 Tan, 18 tooth, RH.......................17271-5 6.74
Type 3 Tan, 19 tooth, RH.......................17271-6 7.60
Type 3 Orange, 20 tooth, RH.................17271-7 8.02
Type 3 Purple, 21 tooth, RH..................17271-8 7.11
Old May 5, 2007 | 10:26 PM
66GTKFB's Avatar
66GTKFB
I believe the gear inside the transmission is fixed, not changable. The difference in gears and tire size are the deciding factors. So far, your tire size, diameter, needs to be included. All taken into consideration, a 19 tooth may be a good starting point. I don't remember where or when or how much of a certain adult beverage was consumed, but a one tooth change is equal to five mile per hour.
Jim
mtgldr
Feb 3, 2024 09:00 PM
articman
Jun 21, 2018 11:45 PM
MusicCity615
Sep 12, 2015 07:05 AM
algregory
Sep 11, 2015 11:44 AM
Emblazoned
Sep 3, 2015 10:45 PM
