Stereo Install
Old May 2, 2007 | 02:43 AM
mat11089's Avatar
mat11089
Default RE: Stereo Install
I beg to differ that rear speakers dont add quality.I run 6.5 components up front and 6x9 3 ways in the back,2 12's,headunit,and 2200 watts.The sound quality and depth of sounds is way better than with just one or the other like my friends 65.Its a good idea to run an extra battery or cap or both like i did.
Old May 2, 2007 | 03:07 AM
noroof66's Avatar
noroof66
ORIGINAL: restomod66
Here is how my 66 coupe is set up!!!
Wow restomod66, I haven't seen that stuff in awhile. I used to work for Pioneer back then.
Old May 2, 2007 | 11:27 AM
MrMainEvent24's Avatar
MrMainEvent24
Yeah, I am still running the generator. Would there be any way to run this system without having to worry about the generator?
I really like the way those subs and amp are mounted in the trunk, but I am worried that my 2 12" subs won't fit. Do you remember if there was any more clearance room to get 2 12"s in that same spot?
Rustycoupe - how did you mount that in the glovebox, and what kind of support do you have behind it to hold up the headunit? Do you have to have the glovebox open to change the channels and such, or is there a way you can get the remote to work with it closed?
Old May 2, 2007 | 02:54 PM
PReal's Avatar
PReal
ORIGINAL: mat11089
I'm sorry but to even mention a cap means you have little to no expereince in quality car audio. If you read the information sticky in the car audio section it might help you get over the idea of a cap. Caps put more strain on your charging system, an additional battery or an optima would only help if the generator is strong enough to charge them both.
If rear speakers are so great, do you go to a concert and turn around, or do you face the band?
TO answer another question CDT comps will not directly fit any kick panels, but you should simply just have to add a spot for the tweeter. I believe that the kicks are pretyt shallow so you might look into the CDT's with the NEO magnets.
Old May 2, 2007 | 06:56 PM
restomod66's Avatar
restomod66
Yeah,
some times the old stuff works the best with less expense!!!! The music is secondary to the pleasure to drive a classic and have everyonne you drive by give you a honk, hoot, or thumbs up when you pass them!!!!!!
Old May 2, 2007 | 07:54 PM
MrMainEvent24
By the way....my generator is a 15 V and 30 amp.
Is this anywhere near strong enough to power 3 amps 2 subs a headunit and 4 speakers?
Old May 2, 2007 | 08:38 PM
PReal's Avatar
PReal
Simply put .... No.
Even the smallest of amps will consume around 20 amps and the HU will consume a couple and then you have the issue of lights, ignition etc....
Old May 2, 2007 | 08:39 PM
green_blurr's Avatar
green_blurr
frick no get a 90 amp
Old May 2, 2007 | 09:10 PM
five pt oh's Avatar
five pt oh
I've still got the generator and I'm running a single amp (not too big though)plus head unit. Are you guys sayingI'm running the risk of damaging something?
Old May 2, 2007 | 10:41 PM
rustycoupe's Avatar
rustycoupe
MrMainEvent- I was going to start with making a metal bracket but it was too hard. I basically just used Mdf board and just ran with it. I got the dimensions of the hole (i dont have the cardboard insert and it never came with one) in the glovebox and basically made it to that size with a hole for the head unit. I made it (up and down) high enough so that it rests a little bit on the protruding metal from where the hinge mounts. I drilled holes in the side of the glovebox on the "tabs" and am running angle brackets to them. here are some pics
