do these actually work better
Old May 1, 2007 | 10:14 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default do these actually work better
i was wondering if anyone actually knows if these work better than a standard thermostat Hi Flow Thermostats
Old May 1, 2007 | 10:16 PM
mikethebike's Avatar
mikethebike
Default RE: do these actually work better
ORIGINAL: Brandontyler65
I only use Stant. Used a Robert Shaw once on a Jeep and it was doa...the only one I EVER had def from the factory. I don't think anything is better than a Stant
Old May 1, 2007 | 10:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
Ya' know Brandon, I have often wondered that as well. If super flow or maximum flow or Hi flow means that they open up more than a standard thermostat, then I would think that too much water flow would be happening and the water would not stay in the radiator long enough to cool properly, therefore causing overheating instead of right the opposite as we may logically think. Until I see some research on this, I am going to say stay with the standard thermostat if that is working for you.
Old May 1, 2007 | 10:33 PM
Brandontyler65
I ♥ Acer
ya its just that we got some of those in the other day at work and after seing them i wondered why that design isn;t seen more often
Old May 1, 2007 | 11:59 PM
Stevetra's Avatar
Stevetra
Hi flow....I wouldent do it unless you have an oversized radiator.
The only reason I would say such a thing is that when I was but a wee lad, I worked at a shop and a guy came in with an overheating problem, he had drilled a extra whole in his stat thinking this would let more coolant circulate...well it did, but it didnt restrict thecoolant flowenough for the radiator to cool the way it should.
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 1, 2015 08:16 PM
