Axle Spline ?
Old May 2, 2007 | 11:56 AM
dozierstang's Avatar
dozierstang
Default Axle Spline ?
Hey, on my 69 Mach 1, I have a 9" diff. Is there another way to find out what spline (28 or 31) I have on mydiffbesides pulling the axle?
Old May 2, 2007 | 12:02 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Axle Spline ?
Generally most cars received the small axle bearings and 28 spline axle shafts. Exceptions to this were the ultra Hi performance Boss 302’s, Boss 429’s, 427’s, 428 CJ/SCJ and the 429 cars which received the 31 spline carriers and axle shafts. So, it would be pretty safe to say that you have the 28 spline axle.
Old May 2, 2007 | 02:19 PM
gothand's Avatar
gothand
Pull the axle and count them. You don't know what the previous owners did, so short of pulling it, you'll be guessing at the spline count. FWIW, my Currie 9" in my '65 fastback has 31 splines. FWIW2, you can now also get custom axles made in 35 spline and maybe 33 spline(?) for the 9".
Old May 2, 2007 | 05:31 PM
mikethebike's Avatar
mikethebike
ORIGINAL: gothand
Pro-Stock cars run 40's.
Old May 2, 2007 | 09:50 PM
LCC's Avatar
LCC
Stock 9" will have 28. Pull one axle and check, it's very easy. Take the tire off then the brake assy. Then you will see four nuts holding a plate that holds the bearing in place, use the hole between the studs to get at the nuts.Then pull the whole axle out....simple.
Old May 3, 2007 | 12:50 AM
Bentworker's Avatar
Bentworker
You can tell the spline count on OEM 9" axles by lookingat the hub, if it has a recessed oval or D shaped indentation in the end of the axle it is a 28 spline. If it is flat, and has two holes (about 1/2" each) it is a 31 spline.
This is just a general rule, but I have never seen a case when it isn't true on a Mustang 9" (unless it has aftermarket axles)
Peter
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
Sep 24, 2015 09:18 PM
Sep 10, 2015 08:39 PM
