Neutral Safety Switch
Old May 3, 2007 | 11:19 AM
Dutchman's Avatar
Dutchman
Default Neutral Safety Switch
Can someone please give a brief explanation on how to change a Neutral Safety Switch in my 65 Convt, automatic.
Old May 3, 2007 | 11:29 AM
VeronicaScz's Avatar
VeronicaScz
Default RE: Neutral Safety Switch
Hello.It's a very simple replacement. You have to unhook the shifter from the side of the transmission, remove the two bolts holding the old switch onto the side of the transmission, unplug the two two-wire connectors, plug in the the new switch wires and bolt the new switch to the transmission.Nothing to it.
Old May 3, 2007 | 12:41 PM
Dutchman's Avatar
Dutchman
Is this possible to do this without jacking up the car?
Old May 3, 2007 | 01:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
If you are as skinny as a rail and have absolutely no gut, then yes. Nah, you need to get it up on jack stands so you have room to move around.
Old May 3, 2007 | 04:06 PM
scott_m_mil's Avatar
scott_m_mil
Another good old fashon red neck trick is to drive the car over a dip in your yard and lay in the dip It'll give you a few extra inches. Even us skinny guys need that every now and again
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
guitarman376
Sep 30, 2015 05:54 PM
Colin Ringle
Sep 15, 2015 09:27 PM
