Roller Cams; what's the deal?
Thanks again for your input. I found this cam :
http://store.summitracing.com/partde...p;autoview=sku
and thought it might be a good choice as its specs are a bit more agressive then my current cam and I already have Edelbrock heads:
[IMG]local://upfiles/26569/C37D60B07B664A1C8258B912CA621862.jpg[/IMG]
[IMG]local://upfiles/26569/B8C708E25C3A4A8BB81B867BEBF8A423.jpg[/IMG]
That might almost be a bit too much cam depending on whether you dd drive it and how much you wanna turn it. That'll make for a 302 that screams out to6.5-7k rpm depending on intake design. And it might not have the best bottom end street manners depending on your gears, but I dunno anyone who's used it, seems pretty agressive though. Also it seems that cam is standard 302 firing order, so if you have a 351W or a 5.0HO that cam won't work unless you get different damper/flywheel for a 5.0, won't work with a 351w though.
ORIGINAL: gothand
Did you just make that up?
http://www.sciencemadesimple.com/sky_blue.html
ORIGINAL: atomsk680
sky is blue cause of the reflection of all the water on our planet
, i dont have time to read it all, was i correct?
Yeah. The 302 I'm building now is get Crane's Powermax 2031(good price at Summit and it'll work with what I'm doing) is a hyd roller and it's 214dur-.050 intake 220dur-.050 exhaust with a 112lsa and .513" int and .529" exh and they list it as 1,400-5,400rpm
ORIGINAL: atomsk680
yes
ORIGINAL: gothand
ORIGINAL: atomsk680
That said, I'll bet you could probably tell that whopperto ten people with a straight face and probably only one would tell you you're full of it.
ORIGINAL: gothand
Not even close!
ORIGINAL: atomsk680
yes
ORIGINAL: gothand
ORIGINAL: atomsk680
ORIGINAL: atomsk680
yes
ORIGINAL: gothand
ORIGINAL: atomsk680
ORIGINAL: 676869Stangs
That cam is too much unless you just want to race. Try something a bit milder like .220 or .224 with a sub .500 lift. You'll getgreat power and driveability.
T
T
Here is a list of all the roller cams available for a older small block ford at Summitracing:
http://store.summitracing.com/egnsea...115+4294840071
Hereare the specs on the cam I have now:
[IMG]local://upfiles/26569/135BFD926F594029884EE422B3F6847D.jpg[/IMG]
[IMG]local://upfiles/26569/82903EDF6709445AA9092D7EE9390F9E.jpg[/IMG]
Any cam that is listed as a power range that goes up to 6,000rpm is gonna need very good heads, intake, exhaust and gears to work right. And either an aftermarket stall converter or a manual trans
