Roller Cams; what's the deal?
Old May 5, 2007 | 09:43 PM
  #21
Smothers's Avatar
Smothers
Default RE: Roller Cams; what's the deal?
ORIGINAL: 67mustang302
Any cam that is listed as a power range that goes up to 6,000rpm is gonna need very good heads, intake, exhaust and gears to work right. And either an aftermarket stall converter or a manual trans
Well I think i'm covered other then my intake (which is a performer; could just switch up to a performer rpm or like). Tranny is a toploader, I have edelbrock aluminum heads, 600cfm edelbrock carb, long tube headers, 3:25 gears. The engine is balanced, bored .040 over on fresh rebuild, 10:1 compression.
However it is a DD, and I want to keep the idle around 800-850 rpm. Also don't want to have to rev it up like a sports car to get off of every red light and stop sign.
Thanks for the input.
Old May 5, 2007 | 10:30 PM
  #22
67mustang302's Avatar
67mustang302
Then get a roller cam with an rpm range listed as around 1,500-5,500. 3.25 gear prolly won't be enough for a 6,000rpm+ roller cam with a toploader. I got a toploader too, 1st is long enough as it is. You don't want a big cam in a dd. Mines a dd and this is the cam I'm using(got it at summit for $179, for 1.7rr)
http://www.cranecams.com/?show=brows...vl=2&prt=5
With good heads/intake and a decent cam and exhaust you can still make good power and have streetability
Old May 6, 2007 | 12:39 AM
  #23
eZ's Avatar
eZ
I agree your fireing order looks completely off.
[/align]
Old May 6, 2007 | 12:44 AM
  #24
67mustang302
Yeah, make sure you get the right firing order cam, 351W and 302 HO use a different order than 289/302
Old May 6, 2007 | 01:08 AM
  #25
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
ORIGINAL: Smothers
Thanks again for your input. I found this cam :
http://store.summitracing.com/partde...p;autoview=sku
and thought it might be a good choice as its specs are a bit more agressive then my current cam and I already have Edelbrock heads:
[IMG]local://upfiles/26569/C37D60B07B664A1C8258B912CA621862.jpg[/IMG]
[IMG]local://upfiles/26569/B8C708E25C3A4A8BB81B867BEBF8A423.jpg[/IMG]
i have that cam that you showed in the images its really nice actually it screams compared to whetever was in my 289 b4
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
junior04
Sep 28, 2015 10:53 AM
