Flywheel Dust shield ??
Old May 5, 2007 | 12:16 PM
chrisal's Avatar
chrisal
Default Flywheel Dust shield ??
I noticed that the car i am about to pull the engine on(66 convertible) has no dust shield. It's an automatic, so i am not sure what the dust cover looks like. Is it a large one piece unit like the manual trans cars use? Does anybody have a pic. Also, i haven't had any luck finding this part on vendor sites. If somebody could post a link i would really appreciate it.
thanks!
Old May 5, 2007 | 01:12 PM
dnswwood's Avatar
dnswwood
Default RE: Flywheel Dust shield ??
What Motor?
Jeff
Old May 5, 2007 | 01:19 PM
VeronicaScz's Avatar
VeronicaScz
Hello.They call that the inspection plate for some reason. Here's what it should look like.
Old May 5, 2007 | 01:38 PM
chrisal's Avatar
chrisal
Thanks! the motor is either a 289 or a 302-not sure yet. i havent been able to crawl underneath the car yet and remove the starter motor to check the block numbers. I assume the plate can be removed easily and is like the early chevrolet 327 engines where the inspection cover/dust shield is held on by about 5 bolts. Is that correct?
thanks again!
Old May 5, 2007 | 01:43 PM
VeronicaScz
Hi again.It's held on by four bolts. It's the same part on a 289 and an earlier 302. If the car has a C-4 transmission, then it's the part shown in the pictures. Happy hunting.
Old May 5, 2007 | 04:25 PM
chrisal's Avatar
chrisal
Is this what i need to tell the owner to order??
http://www.restoremustangs.com/Trans...search_group=1
Old May 5, 2007 | 06:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yep, that's it.
Old May 5, 2007 | 06:24 PM
66GTKFB's Avatar
66GTKFB
Actually, on a C4 transmission, it's held on by two 5/16-18 x 5/8 hex head bolts with an attached split ring lock washer (Ford p/n 42719-S8). They were zinc plated from 64 to 67 and phosphated 68 and later.
Jim
Old May 5, 2007 | 06:39 PM
VeronicaScz
ORIGINAL: 66GTKFB
Jim
Hi again.Yup. I should have been a little more specific. There are two bolts at the bottom that actually hold the thing on.It tucks up under the big plate that's between the flexplate and the block and you have to just loosen the two bolts towards the bottom of the other plate to tuck the inspection plate under the other one. If you look at the pictures you can just make out the other two bolts. But yes, there are only two that that go through a hole in the inspection plate
Old May 6, 2007 | 02:03 PM
mikethebike's Avatar
mikethebike
ORIGINAL: VeronicaScz
What it's really for is toservice the transmission. You have 2 1/8" pipe plugs on the converter to drain the fluid. Without the plate you would need to remove the transmission to replace all the fluid.
6bangr
Feb 15, 2016 07:40 AM
jrrhd73must
Oct 2, 2015 09:17 PM
junior04
Sep 28, 2015 10:53 AM
dudeguy421
Sep 24, 2015 11:16 AM
ccdguy
Sep 19, 2015 05:20 PM
