Heater core
Old May 5, 2007 | 10:19 PM
robert912004's Avatar
robert912004
Default Heater core
How hard is it to replace a heater core in a 65? Do I have to remove the glove box liner? Is their an easy way or short cuts?
Old May 5, 2007 | 10:24 PM
67mustang302's Avatar
67mustang302
Default RE: Heater core
I did mine in my 67, is was pretty easy, just be careful not to break the fiberglass/plastic housing that the core sits in, I had to superglue mine back together, works fine though
Old May 5, 2007 | 10:42 PM
66GTKFB's Avatar
66GTKFB
I got to play Soaring (aka Glen) here, go to the FAQ section and take a look. If the instructions are not there, they should be.
Jim
Old May 5, 2007 | 11:20 PM
JamesW's Avatar
JamesW
The search feature always helps look for previous discussions.....
https://mustangforums.com/m_3120515/tm.htm
dodgestang's Avatar
dodgestang
There are no short cuts to replacing the heater core in a 65....then again it only takes about a half hour.........
Old May 6, 2007 | 02:31 AM
66GTKFB's Avatar
66GTKFB
When you buy the core, get the gasket set, new hose and clamps. Be careful of the defroster plenum, it's cardboard and very fragile. You might consider a new plastic one.
Jim
djbigskrilla
Sep 20, 2022 01:04 AM
mrtrodonet
Sep 19, 2020 03:12 PM
Seanam
Oct 4, 2015 10:15 AM
Calizic
Aug 28, 2015 01:46 PM
Mnuckolls
Aug 9, 2015 08:54 AM
