rear disc questions.
Old May 8, 2007 | 07:26 PM
  #21
superdavid's Avatar
superdavid
Default RE: rear disc questions.
I just called the company thats building my rear end... It should ship tomorrow and they said it has vented brakes similar to that of a 95-96 Explorer I believe...
Old May 8, 2007 | 09:32 PM
  #22
68EFIvert's Avatar
68EFIvert
Thanks for the link James. Just what I was looking for. I don't have access to the original 4 wheel disc distribution block, do you guys know if there is a difference between drum and disc. I think I will order a distribution block from summit that has a built in brake switch and proportioning valve. I don't like the current brake light switch I have and that would kill two birds with one stone. I am a novice at everyting I have done to my car so I wouldn't doubt that I don't have the calipers adjusted correctly.
Old May 8, 2007 | 10:19 PM
  #23
mikethebike's Avatar
mikethebike
Your problem is the residual valve which is set at 10 lbs. to prevent the springs on the shoes from pushing the fluid back into the master cylinder. You need a block with a 2 lbs. residual.
musnicki
Sep 23, 2015 07:11 AM
uberstang1
Sep 21, 2015 09:04 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Gabe_mlcc
Sep 7, 2015 11:56 PM
cbird1177711
Sep 2, 2015 08:51 PM
