Starter overheating
Old May 12, 2007 | 10:36 PM
rcdblink716's Avatar
rcdblink716
Default Starter overheating
I just put a 342 stroker in my '65 mustang. It's 11:1 compression and I have a stock starter. It starts fine when cold but once the car gets warm and you shut it off, it won't start for hours. The battery is good and the alternator is charging. It is acting as if the starter isgetting heat soaked. So I put ceramic coated headers and a heat shield on the starter and it is still just as bad. Do you guys think I need a different starter or is there another problem? Any starter recommendations would be appreciated. Thanks in advance ya'll.
Old May 13, 2007 | 12:05 AM
Scott H.'s Avatar
Scott H.
Default RE: Starter overheating
Old May 13, 2007 | 01:02 AM
rcdblink716
It's not a voltage drop, the car starts fine, but not when hot. Obviously it can be turned by hand, it was built right. I know a 16 minute quick test but thanks for the input.
Old May 13, 2007 | 01:57 AM
Scott H.'s Avatar
Scott H.
Old May 13, 2007 | 02:06 AM
rcdblink716
Iwasn't trying to upset you. Shouldn't be so quick to get your panties in a bunch. I was just explaining that I've already been through the basics. 16 minute quick test is a series of starting and charging tests.
Old May 13, 2007 | 02:36 AM
Scott H.'s Avatar
Scott H.
Old May 13, 2007 | 02:43 AM
gothand's Avatar
gothand
What is your initial timing set at? If it is too far advanced, it will be difficult to turn over while it is warm.
Old May 13, 2007 | 02:45 AM
JamesW's Avatar
JamesW
+1 on the PMGR mini starter. They are less prone to heat soak from headers due to their size. You might also try retarding your timing a couple of degrees and see if that helps.
Old May 13, 2007 | 03:08 AM
rcdblink716
My initial timing is set at 10 degrees and my digital MSD box supposely retards 9 degrees, I think, during start up.
Old May 13, 2007 | 03:52 AM
andrewmp6's Avatar
andrewmp6
if you have bare headers painting them with high temp paint can help so can wraping them but they are right you need a mini high troque starter
BOB ROME
Jul 26, 2023 01:54 PM
mungodrums
Sep 29, 2015 09:18 PM
logan409
Sep 26, 2015 07:43 PM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
