Engine block plug shot off
Old May 15, 2007 | 12:03 AM
onuliakattack's Avatar
onuliakattack
Default Engine block plug shot off
I had my block done a little over a year ago at Napa machine shop and have been putting my engine together ever since, anyways im still breaking the engine in and havnt really been able to drive it anywhere becuase my tranny wont shift out of first, so i have been starting it everyday and running it for about a half hour periodically revving it to about 2500 rpms for a couple minutes, today i fired it up and it seemed to be fine but after i revved it up to about 2000 rpms i saw a bunch of coolant on my driveway so shut it off and found the plug shot off from the block, Napa installed these plugs, so shouldnt they be the ones to rip the engine out and reinstall them?
[IMG]local://upfiles/22269/32B4CD604B01408E8A3ECF10767789AB.jpg[/IMG]
Old May 15, 2007 | 12:05 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Engine block plug shot off
sure you didnt overheat it??
Old May 15, 2007 | 12:26 AM
onuliakattack
Im sure it wasnt overheating, the temp needle was only a 1/4 of the way up and it had only been running for 4-5 minutes or so.
Old May 15, 2007 | 12:32 AM
Aussie66Fastback's Avatar
Aussie66Fastback
if they did the rebuild then yes they should fix it.
you can only ask politely and then see how they react
Old May 15, 2007 | 12:46 AM
JMD's Avatar
JMD
ORIGINAL: Aussie66Fastback
My guess is that yes the machine shop will replace and install the plug, but I bet they will not pull the engine if the engine needs to come out to do so.
Looks like it can be put in without pulling the engine though.
Old May 15, 2007 | 12:49 AM
onuliakattack
I dont know if you can put it in without pulling the engine, its right above the motor mount, but i guess i will call them up tomorrow and see how generous they are.
Old May 15, 2007 | 12:54 AM
my77stang's Avatar
my77stang
just a freeze plug, musta been a loose fit/bad plug
honestly, i know it sounds kinda cheesy but the best way to fix something stupid like this is with a rubber expanding plug. stick it in there and tighten the nut up to seal it off. they work perfectly and you'll be good to go WITHOUT pulling the motor (never gonna knock in a new plug with it sitting in the car like that)
a few examples i found
Old May 15, 2007 | 01:02 AM
JMD's Avatar
JMD
ORIGINAL: my77stang
I like your idea.
I do want to say that if this solution was not available, I betca I could get a plug in that hole without pulling the engine. Therewould bea lot of incenive for me to get that sucker in......... hmm pull the motor, or get that plug in without pulling the motor,,, I will go for option 2
It looks to me that by removing the engine mount it would be reasonably easy to get that plug in.
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
Itzjoe
Aug 26, 2015 08:15 PM
Gary Ugarek
Aug 26, 2015 08:41 AM
kdryan
Aug 21, 2015 04:01 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
