Micro Brake Lock.
Old May 17, 2007 | 04:14 PM
68EFIvert's Avatar
68EFIvert
Default Micro Brake Lock.
Have you guys ever heard of a micro brake lock? Or should I invent one.A guy I know said I should get one for my car. I vision a distribution block type of thing that will lock you brakes when activated. Simplyhold downthe brakes when you stop and then press a button (which can be hidden)that activates a valvewhich will close the brake lines locking the fluid in the brakes. Is there such a thing and is so where do you get them? I tried a google search and coudn't find any products. Thanks.
Old May 17, 2007 | 04:29 PM
maverick75's Avatar
maverick75
Default RE: Micro Brake Lock.
line lock...jegs sell a cheap kit
Old May 17, 2007 | 04:37 PM
superdavid's Avatar
superdavid
http://www.jegs.com/webapp/wcs/store...10002_90726_-1
Check this one out, it looks pretty good... B&M
Old May 17, 2007 | 05:41 PM
gothand's Avatar
gothand
I think you're talking about a Mico Lock which is a brand name which has been used generically, kind of like bandaid and coke. www.mico.com
http://cgi.ebay.com/ebaymotors/MICO-...QQcmdZViewItem
Old May 17, 2007 | 05:51 PM
68EFIvert's Avatar
68EFIvert
I was thinking of micro lock and not a line lock. I don't have access to ebay at work but the site looks like that is the direction I am looking. I want something that locks all 4 brakes. Kind of a non-traditional theft prevention. Doesn't make all the noise and can be very discrete. Thanks for the link.
Old May 17, 2007 | 10:09 PM
royal68's Avatar
royal68
from that website (mico.com) it looks like these are for heavy equipment/delivery applications as temporarty backup to the parking brake - not extended use parking brakes?
too bad, still haven't gotten my p-brake adjusted to work correctly w/ the ssbc rear disc brakes...
Old May 18, 2007 | 02:20 AM
Cruzzar's Avatar
Cruzzar
You might want to check with a dune buggy supply, many years ago theysold a locking device similiar to what you described. It was used as a parking brake. You would put your foot on the brake pedal and then depress the plunger on the locking device and it would keep pressure locked on the wheel cylinders until you pressed down on the pedal again.
Old May 18, 2007 | 02:34 AM
66GTKFB's Avatar
66GTKFB
And they didn't work that well. I had that setup in my sandrail and took it out. Besides, it was a single line brake lock. A 68 has a dual master cylinder so where would you put it? Fronts or rears? Or two?
Jim
Old May 18, 2007 | 03:02 AM
gothand's Avatar
gothand
Like Jim says, the Mico lock isa pretty crappy parking brake. Not only are they prone to bleeding down after awhile, they provide no backup to the hydraulic brake system. FWIW, Cal4Wheel does not allow them in lieu of a functioning parking brake on their organized runs.
Old May 18, 2007 | 03:15 AM
66GTKFB's Avatar
66GTKFB
I just remembered, my 'rail' had no front brakes and had hydraulic turn brakes - who needs abrake pedal.
Jim
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
