Look at this rusty hole
Old May 21, 2007 | 07:42 PM
hity645's Avatar
hity645
Default Look at this rusty hole
So while my dad started the welds on the floor I took some pics of the rusty areas and wanted to share this nasty spot on the Passenger side rear window. First picture is an upside down look.
http://i161.photobucket.com/albums/t...5/100_0459.jpg
http://i161.photobucket.com/albums/t...5/100_0457.jpg
Were not quite sure how to fix this without screwing up the holes for the chrome that goes around the window.
The driver side also has a couple holes but they look rather simple to fix.
Old May 21, 2007 | 07:51 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Look at this rusty hole
I don't know except maybe POR15 it real good, then fill it in with something like JB Weld, then smooth it down and redrill the holes.
Old May 21, 2007 | 07:55 PM
hity645's Avatar
hity645
Got another pic
http://i161.photobucket.com/albums/t...owerWindow.jpg
I dont think we'll start fixing holes until the car gets blasted, that way we know exactly whats rusted and how bad.
What do you think if we filled it in with a welder and grinded it down smooth? And re drilled the hole..
Old May 21, 2007 | 08:08 PM
Soaring's Avatar
Soaring
I ♥ Acer
Welding it and grinding it down is the preferred way. That's what a good body shop would do.
Old May 21, 2007 | 08:27 PM
jaw66's Avatar
jaw66
Those areas look fairly flat. I would cut it out and make a patch for it. Should be simple depending on your skill level but doable either way. Good luck
jwog666
Dec 27, 2021 08:09 PM
GPR
Dec 16, 2015 12:21 PM
jrrhd73must
Oct 2, 2015 09:17 PM
shrkbate
Oct 2, 2015 08:25 PM
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
