Instrument Lights
Old May 23, 2007 | 03:15 AM
mat11089's Avatar
mat11089
Default RE: Instrument Lights
maybe a dumb or late statement but when the lights are on did u turn the headlamp switch to see if the dash lights come on?just tryin to narrow out the obvious
Old May 23, 2007 | 11:08 AM
VeronicaScz's Avatar
VeronicaScz
Hello.Sounds like either the dash ground wire isn't connected or all of the bulbs are burnt out. The dash ground isn't part of that big connector that plugs into the dash harness. If the dash turn signal indicator lights also don't work it it won't be a headlight switch problem.Hope that helps.
Old May 23, 2007 | 05:55 PM
ponyx2's Avatar
ponyx2
Thanks for all the good info. I will check the dash ground strap. The signal indicators work on the dash. Is the ground strap the usual braided wire or an actual strap piece of metal. I swear I don't remember seeing one located anywhere on the dash itself.
Old May 23, 2007 | 08:58 PM
ponyx2's Avatar
ponyx2
MYSTERY SOLVED! Checking voltage at the fuse, had good power there. Check the terminal at the harness connector....dead. To make a long story short, the fuse made connection ONLY when pushed on with a test light, otherwise it was dead. Chalk one upto the experience book.
Old May 23, 2007 | 09:05 PM
Soaring's Avatar
Soaring
I ♥ Acer
Glad you solved the problem. Now, go charcoal a steak and ears of corn and sip on a cold one while you are doing it.
Old May 23, 2007 | 09:08 PM
66GTKFB's Avatar
66GTKFB
Welcome to the relm of glitches, bugs and other electrical vermin. Nice job on figuring out the problem.
Jim
Old May 23, 2007 | 09:44 PM
ponyx2's Avatar
ponyx2
Thanks, you 2 are always there to help. In fact, I think I hear a cold one calling me now, lol.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
