Quick Wheel/Tire question
Old May 26, 2007 | 03:01 PM
CrashBob's Avatar
CrashBob
Default Quick Wheel/Tire question
I'm considering a set of 16X7 4x114.3wheels with 205/40/16 tires. Does anyone see a problem with these fitting on my '65 coupe?
Thanks
Old May 26, 2007 | 07:27 PM
JamesW's Avatar
JamesW
Default RE: Quick Wheel/Tire question
Hey Bob, What's a 4x114.3 wheel?Can you tell us the wheel, the backspacing (in Inches), and ensure it's a 5 x 4.5" stud pattern.
This is a comparison between the 16" wheels you are suggesting and the 16's I'm running on my 65. As long as you go with a 16x7" wheel, with at least a 4" backspacing..you should be ok.
You know of course you're going to be riding on rubber bands. 3.23" tire height will look a bit odd.
Dimension
Tire A: 215/55 R 16
(25 x 8.46 x 16)
Tire B: 205/40 R 16
(22 x 8.07 x 16)
Difference
Width
Sidewall height
Overall height
Circumference
8.46"
(215.00mm)
4.66"
(118.25mm)
25.31"
(642.90mm)
79.52"
(2019.73mm)
8.07"
(205.00mm)
3.23"
(82.00mm)
22.46"
(570.40mm)
70.55"
(1791.96mm)
-0.39"
(-10.00mm)
-1.43"
(-36.25mm)
-2.85"
(-72.50mm)
-8.97"
(-227.77mm)
Old Jun 12, 2007 | 12:13 AM
brapp's Avatar
brapp
With that size tire I think you will be more than fine. Don't go with 225/55/ZR16 up front though. I have them mounted on Torque thrust II 16X7 rims with 4" backspacing and they're hitting the very front part of my fender. It's not a issue vertically but when I turn the tires left or right towards the inside of the fender they rub. I either need some smaller tires rims or rims with bigger backspacing and I like to keep the rims. This is a very expensive mistake. I'm wondering if a 205/55/ZR16 on the same rim will save me. Anybody have any ideas??????
Old Jun 12, 2007 | 01:54 AM
JamesW's Avatar
JamesW
I'm running TTIIs 16x7s with 4" BS on a 65. 215/55-16s and I don't have a front rub problem. The difference between 225s and 215s is about 1/4" in radius. I have almost 1" clearance to my front fender lip.
Take a look at your front end alignment. You may have significant shims pulling those front wheels forward.
Old Jun 12, 2007 | 09:44 AM
thunderize's Avatar
thunderize
I am running a 225/45/ZR17 on the front with no tire rub.
Old Jun 12, 2007 | 09:53 AM
andrewmp6's Avatar
andrewmp6
heres a good link http://www.dodgestang.com/mustang.htm
Old Jun 12, 2007 | 10:39 AM
Norm Peterson's Avatar
Norm Peterson
ORIGINAL: CrashBob
Thanks
Not likely to be a problem getting them to physicallyfit.
But I see a huge problem with the load capacity of those little tires. Those tires are rated at only about 963 lbs, and a car of around 2900 lbs curb weight should be riding on tires with more like 1300 lbs rated capacity. That's a 205/55-16 tire . . .
Norm
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
