Front wheel clearance
Old May 26, 2007 | 03:02 PM
bsltx's Avatar
bsltx
Default Front wheel clearance
New to this forum, hello
I just bought a 66 coupe and when I put the front wheels on, they both rub the front of the front fenders. I have 225/60/15 and according to the research they should fit. I have had the same combo on other 65-66 stangs with no problem.
Can you adjust the fore/aft position of the front wheels?
Thanks,
Brian
Old May 26, 2007 | 03:37 PM
VeronicaScz's Avatar
VeronicaScz
Default RE: Front wheel clearance
Hello.Do they rub all of the time, or just when you're making a left/ right turn? Do they just do it in reverse? It probably will either be poorly fitted, cheap repop fenders or a strut rod problem of some sort, like bad bushings for example. Hope that helps.
Old May 26, 2007 | 04:20 PM
bsltx's Avatar
bsltx
rubs when turning, yes passenger fender is repro and rubs more.
all front end is new, suspension etc.
can you adjust the for/aft of the a arms or anything?
Brian
Old May 26, 2007 | 07:13 PM
JamesW's Avatar
JamesW
What backspacing are you running on those? 225/60s on the front are pushing the limits. Did you drop the nose height? Also, did you install new disc brakes or something that may have widened your front track?
Old May 26, 2007 | 07:21 PM
Soaring's Avatar
Soaring
I ♥ Acer
You can run that tall and fat tire, but your backspacing cannot exceed 3.75. Five bucks says you have 7" wheels with 4.25 or wider BS. Either the tires or the wheels have to go.
Old May 26, 2007 | 07:31 PM
JamesW's Avatar
JamesW
ORIGINAL: Soaring
I think it's the other way around. You want to have backspacing greater than 3.75 in order to offset the wheel further into the wheelwell and miss the fender lip.
The problem then becomes if you go too far, you run the risk of hitting the upper arm. 15's can run 4.25 without any problems.
Old May 26, 2007 | 09:23 PM
colostang's Avatar
colostang
Yeah James, that is right. I am running 4.5" on my 17x8 and do not come close to the control arm.
Old May 26, 2007 | 09:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: JamesW
ORIGINAL: Soaring
It's obvious this guy is having clearace problems with those numbers. Like I said before, either the wheels or the tires have to go.
Tivo304
Aug 28, 2023 12:19 PM
Oct 7, 2015 07:02 PM
maestro1024
Sep 21, 2015 02:40 PM
2007CalSpec
Sep 9, 2015 05:37 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
