domelight wiring
Old May 27, 2007 | 12:32 PM
tommus66's Avatar
tommus66
Default domelight wiring
I am changing the headliner in my 66 coupe and I want to put in a domelight from a 67(maybe). Can anyone tell me how I can wire this up so that the light turns on when I open the door and can be turned on manually with the door closed? any schmatics will be greatly appreciated!
Thanx-Tom
Old May 27, 2007 | 12:33 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: domelight wiring
maybe check out www.mustangmonthly.com or www.mustangandfords.com they have tech articels on line and i know ive read that article in the mag
Old May 27, 2007 | 12:40 PM
tommus66's Avatar
tommus66
when I put in "domelight" on the search button for both those magazine web sites,I getno results.
Old May 27, 2007 | 02:23 PM
JamesW's Avatar
JamesW
Simplest way would be to tap into the rear seat courtesy lamp wiring that goes under your rear window deck. Splice the 2 wires to the over head lamp to the matching two wires of the existing lamp.
Old May 27, 2007 | 02:45 PM
66GTKFB's Avatar
66GTKFB
The wiring is the easy part, there is no place to mount a light.
Jim
Old May 27, 2007 | 03:23 PM
tommus66's Avatar
tommus66
thanx guys for all your help!-Tom
Old May 27, 2007 | 03:29 PM
66GTKFB's Avatar
66GTKFB
Just a suggestion, a console has a light mounted in it's rear that will giveyoulight in the back seat area.
Jim
Old May 27, 2007 | 05:17 PM
Soaring's Avatar
Soaring
I ♥ Acer
There's a metal bow aboutan inch widethat goes right across and in the center. You might could figure out a way to screw a dome light to that.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
