reman autolite 4100's
It turns out that many parts stores have remanufactured 4100's for 60's 289's. I've got enough parts and experience to "check their work".
There are a couple of versions...Does anyone have a carb service tag number off a 1966 v8 C4 car (A-code)? I think I am going to go ahead and order and see what arrives (there is no obligation to buy). Could you imagine if you could buy K-code carbs this way? LOL
Fred
Fred
I had access to an auto parts warehouse a few years back and all the rebuilt 4100 carburetors I looked at were other than Mustang types. Some went back to a1961 352 CID engines. On the other hand, I found a correct distributor including the date code in the same store. Make a list of the 'cast in' codes located on the left front mounting ear for the carbs that apply.
Jim
Jim
kragen was the one i called with a C6ZF-B tag...they said they could get them? i wonder if they can? can you check stock at your supplier as i'd bet anything it isnt on the store shelf...
na all i got on the shelf are holley and edelbrock carbs along with edelbrock heads and intakes and msd dizzys and wires and all that, i rarely have points in stock i am the only other person that knows something about carburetors in my store same with spark plug heat ranges and all that good stuff yet i the short end of the stick at my store anywho i'll look into it tom
skiprCH
Sep 4, 2005 02:32 PM
