Engine getting this hot?
Old Dec 29, 2004 | 07:01 PM
1MeanMach's Avatar
1MeanMach
Default Engine getting this hot?
I just put a new thermostat in my Mach 1, along with new coolant, obviously. The day after, I've only driven about a mile when I notice my temp gauge reading 240 degrees. The gauge continues going up till it hits about 280, then quickly drops to about 200. Then it slowly works its way back down to and stays at 190 degrees, which is where it should be with the new thermostat. I check everything, find no leaks, and make sure there is enough coolant. The next morning, I start it up and start driving again, and it does the same thing. It never overheats, stalls or even idles poorly when the gauge says it's running this hot. The stock gauge doesn't work, so it's got an aftermarket on on it, mounted under the dash. Is this gauge just no good, or is it really getting this hot before the thermostat opens up? Is this even typical?
Old Dec 29, 2004 | 07:02 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Engine getting this hot?
might have had air in the system
Old Dec 29, 2004 | 07:07 PM
1MeanMach's Avatar
1MeanMach
it's still doing it
Old Dec 29, 2004 | 09:43 PM
1MeanMach's Avatar
1MeanMach
Nevermind. It is overheating and boiling over. Now I gotta find out why...
Old Dec 29, 2004 | 10:18 PM
vfast's Avatar
vfast
I ♥ Acer
md told you...this is why I only buy mr gasket hipo stat..as it has a bigger ofice for more flow but it is balanced with a small hole drilled in it for that reason
Old Dec 30, 2004 | 06:59 AM
Soaring's Avatar
Soaring
I ♥ Acer
First, make sure you put the thermostat in correctly, and not upside down. Secondly, take the cap off and let it run at idle for a long time to clear out any air in the system. In other words, burp it. Also, make sure you have enough 50/50 mixture of anti-freeze in the system. I will assume this was not happening before you changed the anti-freeze and put in the new thermostat.
Old Dec 31, 2004 | 06:15 PM
Mustangood's Avatar
Mustangood
Well from my experience, I was having a similar probolem. It did boil over. I checked everything, new thermostat. I took a close look in the radiator and relized there was a ton of buildup and deposits in the radiotor blocking the flow. New radiator, problem fixed
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 1, 2015 08:16 PM
