1973 project
Old Oct 8, 2007 | 07:20 AM
  #111
73 Sportroof's Avatar
73 Sportroof
Default RE: 1973 project
The snow started melting Sunday so I decided in the afternoon to adjust the carb a little.
Carter AFB 625. I started with 400 primary with 7037 rods, silver springs and 395 secondaries.
I changed to 401 primary with 7342 rods, orange springs and 398 secondaries.
It seemed to run better. I broke traction on the shift to 2nd (auto). Felt like it had more power , but from a dead stop I punch it and it falls on its face. I let off and it starts to move and then I punch it and it launches.
Should I go back to the 7037 rods? silver springs? or both?
The accelerator pump is in the hole closest to the carb.
Old Oct 15, 2007 | 07:57 AM
  #112
73 Sportroof
I advanced the timing a few degrees ( 12? I didn't put the light on it ) and it takes off better now. How much advance is too much? Does it matter as long as it doesn't detonate and runs cool? I still have the vac advance plugged off.
With the initial timing set at 10 and the vac plugged I have 34 degrees total. With vac it is around 40.
Old Oct 15, 2007 | 12:50 PM
  #113
Hawkins 812's Avatar
Hawkins 812
As long as your car responds good to your timing, your fine. I currently have 16 initial (aggressive) with 24 mechanical, so a total of 40 degrees. It takes some trial and error or a good dyno tune to find your car's "sweet spot". You might even advance your intial a little bit while your vac-advanced is UNplugged.
Old Oct 16, 2007 | 07:33 AM
  #114
73 Sportroof
Thanks, I will try a little more advance this weakend and see what it does.
mustangheaven
Jan 3, 2016 11:20 AM
mustangheaven
Oct 7, 2015 10:23 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
