blown head gasket
Old Jun 2, 2007 | 04:01 AM
IM RICKY BOBBY's Avatar
IM RICKY BOBBY
Default blown head gasket
heymy friend hada blown head gasket, i guess he took the head down and got them worked on..and so he'sback to putting his engine together... then he asked me a question, but i wasnt quite sure about... he asked me "so i have drained all the oil/water from the bottom of the oil pan. do i put something special in theoil" and i wasnt too sure so i figured i'd ask you guys since you guys have probably expirenced this before... oh i did mention that i had heard a few different things to do from different ppl. like 1) add 3 qts straight 30 wieght oil, and 2 qts diesle fuel (all in the oil system) run the car til hot and then drain. then add normal oil and ur good to go... the other one is 2) just go down and buy the crappiest oil u can get and maybe some additive and run the car til hot and then drain and just add normal oil and ur good to go on that too.. are any of these good ideas???? any advise i could give my friend we'd both apreciate it.
Old Jun 2, 2007 | 04:04 AM
longlive289s's Avatar
longlive289s
Default RE: blown head gasket
diesal? never heard that one. maybe soaring has heard of that old trick[8D]
figure it would be fine just fillin her up with whatever motor oil your gonna use
Old Jun 2, 2007 | 04:18 AM
IM RICKY BOBBY
ohh i forgot to mention... when he pulled it apart he had that whipped oil/water stuck in the corners of the valve cover and so he's just worried it might be on the bottom of his pistons or something
Old Jun 2, 2007 | 05:13 AM
andrewmp6's Avatar
andrewmp6
diesel is a new one on me to break a engine in you use whatever weight suits the engine and where you live dino oil after the first oil change like what 500 miles then use whatever oil you like
Old Jun 2, 2007 | 07:39 AM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, I have known guys who supposedly clean the inside of their engines by using oil and diesel, but I have had more sense than to try that. Just use whatever weight oil you are used to and don't worry about cleaning the inside of your engine.
Old Jun 2, 2007 | 12:51 PM
IM RICKY BOBBY
yeah an 80 yr old mechanic told me that one aboutthediesel, i just figured he had gone seenile. so any ole oil should should do the trick and clean that whipped crap off the walls and stuff... awesome ill let him know. thanks guys
Old Jun 2, 2007 | 01:13 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
id just fill her up with oil then change it again in a few days
Old Jun 2, 2007 | 01:25 PM
my77stang's Avatar
my77stang
the whole point is to clean the water out ASAP. whatever he dumps in there, run it for like 10 minutes and then drain. do not give the water any more time than needed to circulate around that motor and potentially screw up a bearing.
i have used kerosene in the gas as fuel system cleaner (it works) and if you smell motor flush oil treatment it smells like kerosene or diesel fuel too. i wouldnt have a problem using it, prolly like 1/2 to 1 quart then the rest oil and again - drain after a couple minutes of runtime.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
kevsgt
Oct 9, 2015 10:12 PM
Dathan
Oct 5, 2015 05:52 AM
Drastang
Sep 30, 2015 03:48 AM
wraith777
Sep 28, 2015 10:49 AM
