brake pedal height adjustment
Old Jun 4, 2007 | 02:02 PM
evilkhemist's Avatar
evilkhemist
Default brake pedal height adjustment
Help, Please!!! I just replaced all the brake lines, master cylinder, and brake booster in my 68 mustang. The car is an original power brake/front disc car. When I was finished replacing everything I noticed the brake pedal was very close to the floor. I did look for the adjustment on the brakebooster rod inside of the car (rod that attaches to the pedal) and there was no adjustment. How do I adjust the pedal higher?
Old Jun 4, 2007 | 02:31 PM
JMD's Avatar
JMD
Default RE: brake pedal height adjustment
ORIGINAL: evilkhemist
My guess is that the rod supplied with your new booster is not the right one, or, if a new rod was not supplied with your booster and had to use the old rod, the booster is a little different, by thesocket for the rod being deeper that the booster you took off.
You might see if you can get a rod from the booster supplier.
Old Jun 4, 2007 | 02:39 PM
66GTKFB's Avatar
66GTKFB
You were supplied with the wrong booster. It's a common problem.
Jim
Old Jun 4, 2007 | 04:58 PM
supermanzx9r's Avatar
supermanzx9r
are you going from manual to power if so you need the power brake pedal i had the same problem , you did the same thing i did order the wrong kit easy fix just order the power brake pedal
Lethaldosage423
Oct 19, 2015 12:12 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
Ghost_Conscience
Sep 23, 2015 02:17 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
Sep 8, 2015 11:50 AM
