pertronix 1
Old Jun 8, 2007 | 08:19 PM
ponyX65's Avatar
ponyX65
Default RE: pertronix 1
pertronix is a very good product crane also make a point less system plus this one has a built in rev limiter!i have ran both on my 65 and i prefere the crane unit, and sice its allhiden under the dis.cap no one knows you have a rev limiter.every time my ex would borrow my mustang i would always lower the rev limiter to about 2800 rpms.
Old Jun 8, 2007 | 08:26 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: cole18cars
OK, started to remove points etc. then found that my dizzy is for a 390 2-v. I am pretty sure I have a 289 2-v. I think the PO changed the dizzy. Will this have any effect down the road. Installed dizzy # C6AF-K, by my book should be C5AF-N Thanks
If your distributor was working well with points, then the pertronix will work even better whether it be a distributor for a 390 or a 289.
4reboy
Feb 19, 2007 04:28 PM
bw71mach1
Jan 25, 2007 08:32 PM
plainsmen
Jun 30, 2006 11:48 PM
nualln
Jun 1, 2005 06:33 PM
Soaring
May 6, 2005 03:27 PM
