Engine starter questions ... any ideas?
Old Jun 6, 2007 | 12:41 PM
highhilleer's Avatar
highhilleer
Default RE: Engine starter questions ... any ideas?
ORIGINAL: Soaring
I guess I have a restomod.
Say it aint so, Joe. What's next, non stock wheels and tires? [8D]
Scuf23 - make sure all connections are clean and tight. I would take the battery and starter to a parts store for a test.
Old Jun 6, 2007 | 01:04 PM
five pt oh's Avatar
five pt oh
this is one of those times when having one of those portable jumpstart packs would be handy. Not only will they help with a weak battery, but I've even used them to start a car that had a bad cell (couldn't evenbe jumped by another car). It's a very handy thing to have when you get stuck, but in this case it could have saved you from needing to take the battery in for testing.
Old Jun 7, 2007 | 09:24 AM
kalli's Avatar
kalli
five pt oh: --> couldn't evenbe jumped by another car
had this issue a lot of times. ... until I bought proper jump leads. The **** you get at petrol stations with plastic clams and thin wire isn't worth 2 cents.
Go for a cable you'd use on a truck and then you won't have this problem anymore
Kalli
Old Jun 7, 2007 | 10:23 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: kalli
Kalli
Yeah, when you jump from another car battery, you aren't jumping through the weak or dead battery, but around it. Kalli is right in that you need good quality cables.
Old Jun 7, 2007 | 10:41 AM
Norm Peterson's Avatar
Norm Peterson
Really basic, but did you get any paint on the terminal(s)? Even a little will increase the contact resistance and cause hard (or non-) starting.
Norm
Old Jun 7, 2007 | 11:25 AM
scuf23's Avatar
scuf23
The terminals look clean - I have not tried anythign since my last post - I will be working on the car this w-e, so I will likely post again with the latest on Saturday PM - Thanks again
Wisconsin 5.0's Avatar
Wisconsin 5.0
I'd make sure the motor is free to spin...stick a wrench on the crankshaft and make sure the darn thing isn't locked up somehow.
Old Jun 7, 2007 | 11:46 AM
scuf23's Avatar
scuf23
I actually forgot to mention that I did check that and the motor does spin
Gary Ugarek
Sep 5, 2015 09:03 PM
fireboss343
Aug 21, 2015 06:25 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
classic69FB
Aug 12, 2015 11:58 PM
HIS S-197
Aug 10, 2015 05:47 PM
