Installing 1966 Bumper Guards
Old Jun 5, 2007 | 03:11 PM
Pmac1234's Avatar
Pmac1234
Default Installing 1966 Bumper Guards
Could anyone tell me how to mount the front and rear bumper guards on a 1966 mustang coupe. The bottom bolt shouldn't be a problem. I see a hole in the valance for that. I don't see where to attach the top. Does the bumper have to come off to mount the bumper guards? Thank you very much for the help
Old Jun 5, 2007 | 03:41 PM
66GTKFB's Avatar
66GTKFB
Default RE: Intalling 1966 Bumper Guards
There is a right angle bracket that boltsto the inner arm on each side that provides the upper support point for the bumper guards. Go to www.npdlinks.com for some reference pictures. Use p/n 17B794-1A in your search.
Jim
Old Jun 5, 2007 | 03:53 PM
Pmac1234's Avatar
Pmac1234
Thanks for the help. I do have that part already. I haven't really looked at the front bumper guards yet. I was starting with the back. Is there any bracket for the rear bumper guard? Should there be a hole to mount the top bolt of the bumper guards in the rear valance?
Old Jun 5, 2007 | 04:44 PM
66GTKFB's Avatar
66GTKFB
For the rear, the bumper may have to be removed. If you do, don't forget to disconnect the license plate light wire first.
The top of the bumper guard is secured by a 5/16-18x1 1/4 bolt to a nut clip on the bumper guard from inside the trunk. The bottom of the bumper guards go to two different brackets. Each bracket is held to the body by two 5/16-18x1 1/4 bolts each, the right hand side to nut clips in the body and the left to nut clips on the bracket with the bolt coming in from the trunk. The guards, each, have a 5/16-18x1 1/4 bolt from the bracket to a nut clip on the guard.
Jim
Old Jun 5, 2007 | 05:13 PM
connor90's Avatar
connor90
i did not have to take the bumper off when i put mine on...here let me go snap a few pics real quick to give you an idea of where they mount
Old Jun 5, 2007 | 05:21 PM
connor90's Avatar
connor90
tell me if this helps...the bolt that is used to secure it is the small one to the left of the larger bumper bracket bolt.
[IMG]local://upfiles/53517/05819804D5F541098040A90C283554CA.jpg[/IMG]
[IMG]local://upfiles/53517/C9C7104FC701469BBF215AC13F7EAA00.jpg[/IMG]
[IMG]local://upfiles/53517/A01D790B38184BB6912B9485779B5DBA.jpg[/IMG]
Old Jun 5, 2007 | 08:23 PM
Pmac1234's Avatar
Pmac1234
Wow! You guys are amazing. I see what I need to do now. Thanks so much for the help.
Old Jun 5, 2007 | 08:34 PM
connor90's Avatar
connor90
you're welcome
glad i could help
Old Nov 11, 2018 | 05:37 PM
Paynter's Avatar
Paynter
Default Rear bumper guards
Hello
How did you install the rear bumper guards without out taking the bumper off?
Thanks
David
prangy
Jan 11, 2012 10:39 PM
2003gtstang
May 12, 2009 09:58 AM
JohnCalvin
Oct 6, 2007 06:05 PM
LPlum
Jul 27, 2007 08:37 PM
Mike D.
Dec 16, 2006 11:26 PM
