Picture request
Old Jun 6, 2007 | 12:41 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Default Picture request
I need to see if anyone has a picture of the parking brake cable & bracket assembly under the car. Mine is clanking, and I have no idea why. It didn't do this before, but I tightened the PB cable, then it clanked, so I loosened it back, and it still clanks.
Oh, and it is an automatic. I am pretty sure that makes a difference
Old Jun 6, 2007 | 01:59 AM
VeronicaScz's Avatar
VeronicaScz
Default RE: Picture request
Hello.What year model is your car?
Old Jun 6, 2007 | 02:10 AM
mySAVIOReigns
Whoa...where did my sig go? lol
It's a 66 Mustang coupe
200ci if that really makes a difference
Oh, there it is
Old Jun 6, 2007 | 02:32 AM
VeronicaScz
Hi again.These are pictures of a 65, but the only difference would be that a 66 has one long cable that goes from one wheel through a curved bracket near the tranny and then back to the other wheel,while the 65 has two cables, one from each wheel, that both hook to a straight bracket. Yup, that's the only difference betweenthis 65 model 4-speed K-code and your 66 6cyl auto.Well, that and fuel economy, but other than that.....
[IMG]local://upfiles/68214/EDCA1321DD874727BDFBDE134F754B53.jpg[/IMG]
[IMG]local://upfiles/68214/7AEA8DB8D405403AA919E7E8E39D367F.jpg[/IMG]
[IMG]local://upfiles/68214/378AF6EF0FA940FD81FE9A02D431EF29.jpg[/IMG]
Old Jun 6, 2007 | 02:37 AM
mySAVIOReigns
From the looks of it (sorry, your AWESOME exhaust is in the way), your bracket which holds the parking brake cable, which goes to the back, seems fairly centered along the driveshaft and in front of it.
Mine is off center (to the driver's side) and it is right even with the U-Joints
Old Jun 6, 2007 | 03:05 AM
VeronicaScz
Hi again.That is very kind of you to notice the exhaust. I hate having ugly exhaust bringing everything else down. I think that you might have found one of the symptoms of your problem. My first mustang was a 66 model 6cyl. The bracket that the cable loops around should be centered on yours also. The lever that has the long spring hooked to it, along with the equalizer rod that is holding the bracket which the cable loops around, has two holes in it. The spring is in one and the equalizer rod is in the other. If you have those two items in the wrong holes, it would do exactly what you have described. Hope that helps.
Old Jun 6, 2007 | 03:15 AM
mySAVIOReigns
Strange, very strange...I will hopefully check on that in the morning, but it makes me wonder how in the world it got that way
Old Jun 6, 2007 | 03:23 AM
VeronicaScz
Hi again.You wouldn't believe some of things that I've seen people do to their cars under the guise of 'fixing' something. If the previous owner did something as silly as that, saw the results, and decided that this would be ok,even though it is easily corrected,I would go over the entire car with a microscope, especially the things that might kill me, like brakes, steering and suspension. Then go to the stuff that might set my car on fire, like the entire electrical and fuel systems. Happy hunting.
daltron
Apr 28, 2016 08:10 PM
treesloth
Sep 28, 2015 07:03 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
orangeboom
Sep 23, 2015 09:43 AM
Demodulates
Sep 18, 2015 11:14 AM
