Upholstry gurus...i need help
Old Jun 7, 2007 | 06:40 PM
  #21
bodyputtyless's Avatar
bodyputtyless
Default RE: Upholstry gurus...i need help
When you finish the upholstrey your hands will ache. You need to get way down into the foam to make the connections. This is what gives the seat its profile once the vinyl is on. If you don't create the form the vinyl will never look taut. I did the seats in my 70 Mach1. High back buckets with the deluxe interior. What a chore it was trying to establish the recesses that make up the seat profile and the supports. But I kept at it and I did it. They look darn good in my opinion.
Old Jun 7, 2007 | 07:19 PM
  #22
ponyx2's Avatar
ponyx2
Forget those books. No offense Jim, I have wasted my money one them. To get your new foam and / or upholstery onto the wires, it does take a little brute force and at the same time using your other hand to "feel" where the prongs of the hogrings are and adjust as neccessary. Trust me, it isn't hard to do, I redid my entire upholstery BEFORE I wasted my money on those books or sending them out. Your results, IF you take your time will come out great, and you can say you did it all yourself!
ORIGINAL: connor90
thanks for the responses guys...i still cant figure it out though. my parents said that if i cant figure it out that they dont want me to ruin it so were going to have to take it somewhere [:'(].
Old Jun 7, 2007 | 08:00 PM
  #23
66GTKFB's Avatar
66GTKFB
Well, if you've done it before, I guess you don't need a book or picture, the one worth a thousand words. I thought I had a copy of one of the books I referred to for a picture but if I did, it's lost in my collection. But I did have a picture of the Ford assembly, so before (excuse me - BEFORE, your own word enhancement) you begin an assembly project, know what you are supposed to do. It's the old testosterone syndrome gone amuck, 'if in doubt, read the instructions'.
Jim
Old Jun 7, 2007 | 08:40 PM
  #24
connor90's Avatar
connor90
ok guys GREAT news...i got one of my seats almost done! i got the bottom compleatly done and the foam attached to the top but i ran out or wire hangers to use for the vinal so im going to have to go try to find some. my hands dont even hurt that bad...im very satisfied with my work so far
thanks to everyone who helped me out...i really appreciated all the input. ill try to finish them up in the next couple of days and ill post pictures when im done for those interested.
Old Jun 7, 2007 | 08:42 PM
  #25
ponyx2's Avatar
ponyx2
My post meant that the books are useless.
Old Jun 7, 2007 | 08:44 PM
  #26
ponyx2's Avatar
ponyx2
Good for you Connor
Old Jun 7, 2007 | 09:14 PM
  #27
stangs67's Avatar
stangs67
Connor- im having trouble taking the whole rear seat out and then putting the new upholstery on
Old Jun 7, 2007 | 09:20 PM
  #28
Soaring's Avatar
Soaring
I ♥ Acer
Obviously, the rear seat has to be out of the car in order to reupholster it.Get your body in the back seat area and straddle the hump while your knees are on the floor pan. Push back on the seat bottom then lift up. Once the bottom is out, you will see two screws on the bottom of the back part at the bottom. Unscredw those and remove the back of the seat.
  #29
connor90's Avatar
connor90
so you cant get it out of the car??
well ours are different years but they should be the same to pull out of the car. just slide the bottom half forward and take that out then pull the top half up and it should come right out. to get the old stuff off i ripped the hog rings off with a huge pair of channel-locks and those worked really good. then just put the new stuff on the same way the old stuff came off.
i have no idea if what i just said makes sense so if you have any more questions just ask and if i cant help you then someone else surely can
edit: dang...soaring beat me to it
Old Jun 7, 2007 | 09:25 PM
  #30
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: connor90
Yeah connor, you don't pull forward on the bottom seat, you have to push it back toward the trunk first to release the hook thing in the middle of the seat right on top of the hump then pull up and out.
