1970 Coupe Conversion
Old Jun 7, 2007 | 12:49 PM
adr3naline's Avatar
adr3naline
Default 1970 Coupe Conversion
Okay, I'm interested in converting a 1970 mustang coupe into a 1970 boss 302 coupe. I would like it to be exactly the same as the original boss 302, but without the fastback top of course. Where is the best place to find detailed specifications of the two models to compare? Also, probably a dumb question, but is the only difference between the 302 and 302 boss engines the manifold and carbeurator going to the 4 brl?
Also, I read a guys restoration process, and he knew a lot of things like how Ford originally put the cars together (I have the restoration guide with assembly diagrams, but his information was different), such as that Ford assembled the entire dash and installed it in one piece, or that there should be overspray with the finish color in this certain location, etc.
Thanks!
Old Jun 7, 2007 | 02:44 PM
atomsk680's Avatar
atomsk680
Default RE: 1970 Coupe Conversion
http://bradbarnett.net/mustangs/time...0/70/index.htm
that site has alot of good pics, as for the engine, the difference between a 302 and a BOSS 302 is that the boss has cleveland heads fitted on a 302 engine, a difficult feat i might add
Old Jun 7, 2007 | 03:14 PM
adr3naline's Avatar
adr3naline
Where can I find exact specification differences? I've been to that web site, and all it says is that the boss has the 4v vs the 2v. Where can I find the differences like you just mentioned with the heads?
Old Jun 7, 2007 | 03:52 PM
atomsk680's Avatar
atomsk680
http://www.mustangandfords.com/techa...clevor_engine/
google is my friend
and as for little things like overspray in areas, that would seem nearly impossible to find out since there were so many boss mustangs that every teeny detail you want to know wasnt even let have a second thought about, just think of it this way, if MCA doesnt care, why should you?
just get it as close as possible as you can from the pics, your not fooling anyone anyway, so why would you want overspray in some areas or a one piece dash, no ones gunna see it.
mustangheaven
Jan 3, 2016 11:20 AM
b8checker
Oct 8, 2015 12:55 PM
mustangheaven
Oct 7, 2015 10:23 AM
b8checker
Sep 30, 2015 07:11 AM
mustangheaven
Sep 29, 2015 11:00 AM
