Shock question
I think Fleabay had a set of one and a half inch lift leaf springsfor about one-thirty-five. I don't think shocks will solve your problem and I don't know what size tires your sporting.
+1 on the other posts; new shocks won't stop the rubbing. Are you running a larger than stock tire size? That would be the most obvious source of the rubbing.
By the way, same thing goes for the springs. Stiffer springs might reduce the number of times you rub when bottoming out, but the problem remains that the tires shouldn't rub even when you bottom out.
treesloth
Sep 28, 2015 07:03 AM
