my 347
Old Jun 12, 2007 | 03:31 AM
valley firearms's Avatar
valley firearms
Default my 347
I just got back from taking my 347 to a builder. He is a Ford man luckily. He has two rails and races every weekend during the season. He is going to disassemble the 347 and clean it making sure all is good. He will be installing head studs as well since bolts were used. I'm pretty stoked.
[align=left] [/align]
Old Jun 12, 2007 | 03:35 AM
JMD's Avatar
JMD
Default RE: my 347
ORIGINAL: valley firearms
[align=left][/align]
Get a girdle!!!!!!!!!,,, uhh for your mains,,,, I used one because they say it is relativly cheap insurance...
Old Jun 12, 2007 | 03:52 AM
valley firearms
Default RE: my 347
Yes Sir, we actually discussed that too.
Old Jun 12, 2007 | 04:34 AM
andrewmp6's Avatar
andrewmp6
Default RE: my 347
hope everything in it is ok i remember the post about the guy trying to give you the run around.
Old Jun 12, 2007 | 09:23 AM
67 evil eleanor's Avatar
67 evil eleanor
Default RE: my 347
Congrads!
Old Jun 12, 2007 | 07:18 PM
Deviousfred's Avatar
Deviousfred
Default RE: my 347
Man I miss my old 347.
It had:
Eagle Forged crank
Eagle Forged H-beams
Probe Flat tops
Gapless rings
Fully balanced rotating assembly
Tri Metal Bearings
Probe Main Stud Girdle
ARP Main Studs
ARP Rod bolts
Half Solid fill block
Zero Deck
O-ringed decks
Comp Cams Custom Grind Solid Roller Billet Cam
Comp Cam Solid Roller Lifters
Timing Gear Drive
PP Billet Balancer
Canfieldrace ported and polished heads
2.02s 1.60s Triple springs
Probe Shaft Mount Rocker System
Canton Pan
UPR Timing POinter
That's about half the list
[IMG]local://upfiles/19285/0A7C7B8E2C654339B31AC02231AAA544.jpg[/IMG]
Old Jun 16, 2007 | 11:50 PM
valley firearms
Default RE: my 347
I may have some bad news. One of the cylinders has a deep scratch. My friend is going to measure the pistons to see if I can go with a bigger bore. That means mucho denero for more pistons. The pistons in there now were $700 on the receipt that I got from Matt.
Old Jun 17, 2007 | 12:20 AM
my77stang's Avatar
my77stang
Default RE: my 347
how'd that happen? how wide? touch hone it, then slap that puppy back together and live with very minor blowby[8D]
Old Jun 17, 2007 | 05:12 AM
valley firearms
Default RE: my 347
It's funny you say that because that is exactly what I was thinking. I will find out how bad it is this week. I ran my finger nail across it and it's about as deep as a busineess card is wide.
Old Jun 17, 2007 | 12:09 PM
my77stang's Avatar
my77stang
Default RE: my 347
oh hell, have them touch hone it in a machine (instead of handheld drill). this will make sure all the cylinders are back to being true (maybe even use a torque plate) and slap it together. use gapless rings and that little scratch will let less go by than you would loose from the gaps in normal rings.
i have once removed rust out of a couple 351M cylinders with sandpaper and a wire wheel and that car actually didnt smoke and still runs. i also used a roofing shingle and skateboard grip tape to knock rust down in the cylinder of a 460 and that thing still runs with no smoke too. so, +1 for macgyver skillz
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
90GT347
Jul 19, 2004 12:36 AM
